Some will be shipped at the end of March, and the remaining units will be shipped starting at the end of April.what is the current ETA for the first shipments of the BX8C?
perfect!Some will be shipped at the end of March, and the remaining units will be shipped starting at the end of April.
Thanks for these tips which will be helpful to me for sure. One last question: you said you also set the master and slave in HFD. Whets the benefit or effect of doing that?
1. connect a SPDIF cable between the two speakers? any downside in using this option?I have 2 options.
1. Connect a SPDIF cable which can send control signal.
2. Reset the slave as a Master so it can do it itself with AES connection only.
2. I don't understand this option - does this mean you now have 2 Master speakers?
Thanks for your help - I'm waiting for my AES cables so soon I will be in the same situation...
Just when I thought I'd understood everything in the manual!Thanks @Grimoire for answering.
There are still some peculiarities with the Hypex amp as I am learning!
The AES connection between master/slave is limited to audio signal and NOT control signal. The result is my slave will not auto go into low power mode and remains fully on indefinitely past the 10 minute timer I set in the master.
I have 2 options.
I have a feeling its going to get more complicated with the BX8C and 4 amp modules.....
I find it odd that this behavior is happening: "The result is my slave will not auto go into low power mode and remains fully on indefinitely past the 10 minute timer I set in the master." - this is clearly a design flaw as if you set it on the master, it should then naturally work for both the master and the slave.Yeah, i have not tried yet, but either option should work - in theory.
Master/slave just relates to control functions, one is controlled by the other ot both are independent
If I encounter the same issue, I'll contact support at Hypex.
so in a use case of using AES for audio signal the normal config is to daisy chain the 2 speakers. What happens if they are daisy-chained AND I add a SPDIF cable? will the audio signal still be passed from one speaker to the other via AES? sorry if this is an obvious answer but it's not trivial to meOdd yes, but not a fault.
In the amp design AES is purely for audio signal. If you want control signal (master sending instructions to slave) in digital domain have to use SPDIF.
When in slave mode that speaker cant access some of the control functions independently.
will do - thank youIf you want autosense on an off I think the easiest solution is to leave both speakers as master - while using AES daisy chain.
Otherwise you can select AES as forced input on slave despite having multiple digital connections.
I think you will need to play around with it to get it working to your requirements
What would be the reason to add an additional connection to a Daisy-Chained connection?so in a use case of using AES for audio signal the normal config is to daisy chain the 2 speakers. What happens if they are daisy-chained AND I add a SPDIF cable? will the audio signal still be passed from one speaker to the other via AES? sorry if this is an obvious answer but it's not trivial to me
drive.google.com
I just did read Appendix A a few times but the use case described - which I suppose is a fairly standard one - when using AES to connect both speakers and then set them as master and slave in HFD doesn't really address how to solve the controls sharing aspect. Or at least the recommended option is not clear.There is a manual about the daisy chain system as Appendix A. Please read the manual first.
AsciLab Manual - Google Drive
drive.google.com
If you want to share the control signal, you have to connect both speakers with Spdif cable and set the Master/Slave function.I just did read Appendix A a few times but the use case described - which I suppose is a fairly standard one - when using AES to connect both speakers and then set them as master and slave in HFD doesn't really address how to solve the controls sharing aspect. Or at least the recommended option is not clear.
Is it to :
1- use AES between both speakers, force the input as AES on the slave in HFD, and use a SPDIF cable between both speakers to share controls? (if that works I will use this option)
or
2- not use AES between both speakers and simply connect them via SPDIF?
OR are both options possible?
