I am still enjoying it a lot.It's not bad, but it seems like it's been out for way too long![]()
What challenge?
If you want less bass distortion, that's what the bass extender unit is for. It significantly reduces that rising distortion below 200Hz.Interesting - thanks for explanation
I'd consider the Neumann KH80 and Genelec 8020/8030.slightly OT...but if I want two active surround speakers to complement the C8C+BX8C fed by an ATV going through the new miniDSP Tide16, what options would you consider? I'm looking for options that wouldn't break the bank for these surrounds but still deliver good performance.
thank youI'd consider the Neumann KH80 and Genelec 8020/8030.
Are you sure you want actives? C6Bs and a handful of class D amps would do just as well.slightly OT...but if I want two active surround speakers to complement the C8C+BX8C fed by an ATV going through the new miniDSP Tide16, what options would you consider? I'm looking for options that wouldn't break the bank for these surrounds but still deliver good performance.
no I'm not sure at allAre you sure you want actives? C6Bs and a handful of class D amps would do just as well.
Two copper speaker wires per surround speaker are easier to run than XLR + Mainsno I'm not sure at all- I just thought I'd also need actives to be "consistent" in my set-up. Is there a benefit to go passives for the surrounds?
I'm not a tinkerer, nor do I aspire to be. AsciLab passives it will be then! thanks all for your inputThe only clean way I can think of to run active surround sound is using Genelec Smart IP.
You then trade the two copper wires for a single Ethernet cable per speaker, carrying both power and data.
Expensive though, and having a mixed Genelec Smart IP/ Ascilab setup with Atmos and ART would be a real challenge to set up.
The F6BS is perfect for surround duties.I'm not a tinkerer, nor do I aspire to be. AsciLab passives it will be then! thanks all for your input
"Content not viewable in your region".Some updates from the Korean thread.
C8C backplate. They chose to name it Studio Monitor, I didn't know that.
The C5 Centre at the middle of the picture, not the bracing. Also note the trapezoid enclosures for the midwoofers in the C8C.
Note the separate box at the back of the C8C for the plate amp. I can't see any further bracing, maybe it's unnecessary because the woofers are dual opposed, or maybe it's just not visible here.
