slowTwitch
- Joined
- Nov 28, 2020
- Messages
- 24
- Likes
- 40
A coin under each spike is the traditional solution, right?is it confirmed that the C8C+BX8C will come with spikes? if so, I need to look into this further as I have hardwood flooring...
sounds about rightA coin under each spike is the traditional solution, right?
If the speaker placement is affected by SBIR, the cardioid behavior of the C8C can help reduce its impact.how would you expect room size to affect the C8C? will they do okay in untreated 3x3 room, or do they need a larger space to shine?
Due to the physical size of the C8T, we are currently optimizing the NFS measurement process.When are the c8t measurements expected.
The BX8C will not come with wheels installed by default. Instead, it will be supplied with dedicated shoes.C8C and sub. Could they be mounted on wheels? At least for the first few moments to find the best position? Do they have a threaded bottom?
So what do you consider an "above SVS" sub brand product?the S6C driver quality is so high I might shoot for a brand above SVS for the subwoofer.. not a dig at SVS
Rythmik is often mentioned. Sometimes HSU or REL. I went with Rythmik and Genelec (which I do not recommend unless you have genelec mains)So what do you consider an "above SVS" sub brand product?
Subs don't get objectively reviewed all that often
Changing Subwoofers doesnt help for "better" bass frequency output, except trying dipole/ripole subs. The best way, in my opinion, is to go on with bass arrays. There are different ways to try: Single-Bass-Arrays that are geometrically placed on one wall. Double-Bass-Arrays (i use) where the single bass array is mirrored on the opposite wall, delayed and changed in dB and there are multi-sub solutions (Welti).the S6C driver quality is so high I might shoot for a brand above SVS for the subwoofer.. not a dig at SVS
Mine are on carpeting so I leave the wheels on permanently. At 123lbs each, it is extremely convenient...The BX8C will not come with wheels installed by default. Instead, it will be supplied with dedicated shoes.
Threaded inserts are provided for the shoes, so users may install aftermarket casters if they wish.
I agree it looks tall and heavy BUT it does come apart so that's a much nicer option than trying to move the stack.Whats the combined weight C8C/BX8C?
Does look like it could be quite awkward to move around on some surfaces, particularly if bolted together
Plenty of people on ASR complain about weight so this solution lets you move it piecemeal / less weight, hopefully everyone will be happy with that.
I haver wooden floors, so intend to put the whole stack on a wheeled base when first setting up, then taking it off once the optimal position is found. And just leave it there.
All true, this part especially I had not considered.Open front, back and side drivers
I've used felt-bottomed furniture slider disks on hardwood floors.I agree it looks tall and heavy BUT it does come apart so that's a much nicer option than trying to move the stack.
Any indication on the expected price yet?Due to the physical size of the C8T, we are currently optimizing the NFS measurement process.
A larger number of measurement points is required, which is taking more time than initially expected.
We expect to have preliminary results available next week.
On the (or, on one of the many) upside(s), this speaker will replace four big boxes in my system so getting it right once, even if it is pretty hard work and takes a while, will result in a much neater and less-obtrusive ( and maybe even better-sounding) system.
All the best,
The combined weight is expected to be around 60 kg.Whats the combined weight C8C/BX8C?
The cylindrical shoes are fitted with felt pads on the bottom, so moving the speakers on wooden or marble floors should not be an issue.
The estimated MSRP for the C8T is around $4500. However, this is not finalized yet, so please treat this as a rough reference only.Any indication on the expected price yet?
