the S6C driver quality is so high I might shoot for a brand above SVS for the subwoofer.. not a dig at SVSThinking to pair the upcoming AsciLabs S6Cs with the upcoming SVS SB3000/R subs.
Any thoughts?
Any thoughts?
And those values are meant as minimum, right? Or is it "ideal"
1: Ascilab Actives use DSP crossover so there's no point in buying high performance, expensive DACs like the DAC8.sorry for the n00b question but I'd like to add 2 surround active speakers to my set-up once I have the C8C+BX8C. I plan to stream from a Wiim Ultra out USB into an Okto DAC8 Pro and then analog out into the different active speakers. But in this set-up I'm missing a device to do the processing/time alignment, right? Is it imperative to use an AV processor for such a use case or is there a way without? thanks!
Usually this.or you run one SPDIF to the left speaker, then a second SPDIF from the left speaker to the right speaker?
The C8C has SPDIF in and SPDIF out.how do people normally use digital input to a speaker like the C8C? it requires a source device with dual SPDIF output, one to each speaker? or you run one SPDIF to the left speaker, then a second SPDIF from the left speaker to the right speaker?
If the speakers are switched to ‘analogue’ input , then it is the usual left out to left speaker , if switched to ‘digital’ input, AES from your streamer to one speaker’s ‘in’ then from theat speakers ‘out’ to the other speaker’s ’in’, daisy chained .how do people normally use digital input to a speaker like the C8C? it requires a source device with dual SPDIF output, one to each speaker? or you run one SPDIF to the left speaker, then a second SPDIF from the left speaker to the right speaker?
What does that mean? Should potential buyers rejoice that they actually have to pay more for no additional services?Reading the last pages of thread shows really the douchebag behaviour of people.
In fact, that price was wrong and was only corrected because we pointed it out.you are discussing about 1k "too high" price offered by Audiophonics
I have a set of Herbie's Gliders under my spikes. Protects the hard floor and allows easy movement, albeit my C6Bs and stands will be considerably lighter than C8Bs...they come in different sizes though for larger/ heavier speakers.@AsciLab
C8C and sub. Could they be mounted on wheels? At least for the first few moments to find the best position? Do they have a threaded bottom?
is it confirmed that the C8C+BX8C will come with spikes? if so, I need to look into this further as I have hardwood flooring...I have a set of Herbie's Gliders under my spikes. Protects the hard floor and allows easy movement, albeit my C6Bs and stands will be considerably lighter than C8Bs...they come in different sizes though for larger/ heavier speakers.
