Curvature
- Joined
- May 20, 2022
- Messages
- 2,072
- Likes
- 3,200
This is certainly false. The main problem here is called speaker boundary interference response, affecting the 100-500Hz range, although the bigger effects tend to happen below 300Hz. This affects all speakers and the issues are nonminimum phase (cancellations from reflections) and therefore difficult to EQ.Does the C8C, as a cardioid-directional loudspeaker, need to be placed far away from walls?
A friend of mine said that when a cardioid loudspeaker is placed close to a wall or a desk, it will form directional lobes, causing abnormal directivity. According to this view, correct placement would require keeping it more than one meter away from surrounding walls. If that’s the case, cardioid loudspeakers would be almost impossible to use in bedrooms or smaller living rooms.
So does the C8C have this problem?
I don't want to write exhaustively on how to assess different speaker radiation patterns with boundaries. Safe to say that cardioid speakers reduce SBIR because they have controlled directivity, with less energy radiating to the sides and back, limiting the strength of reflections, making speaker placement more flexible. The effect is roughly equivalent to reflection control through treatment, although that method is very difficult and far more expensive. Some say that speakers should only ever be flush-mounted monopoles (forward-firing speakers set inside walls so that the baffle is aligned with the front wall's face).
SBIR can be calculated in advance by knowing only speaker and room dimensions. The calculated figures can then be made more precise by applying anechoic speaker measurement data like the kind Ascilab posts.
The rough "rules" for dealing with SBIR involve placing speakers less than 1m away from the front wall, or ideally more than 2m away. These rules are for people who don't want to understand the underlying phenomena and math. I generally counsel most to put their speakers right up against the front wall and not to worry about the ceiling, floor, sidewalls or speaker height. How complex the advice gets depends on how much you want to understand and what your goals are.
