We are considering adding a satin-finish metallic grey color option.Looks very smart, and you can have them in any colour, as long as it's black or white
For a sofa setup, we recommend a height of 60–70 cm, and for a chair, 80–90 cm.Am I right to assume the recommended stand height for the C8C is around 80cm?
Direct streaming to the speaker is not supported. An external streaming device must be connected to the C8C via its digital or analog inputs.Can you stream directly to this speaker? Any plans for built in room correction? Or, plug ins like Dutch and Dutch has Bacch for their 8c?
The color tone is the same as the F6Bs. However, the texture will be smoother.Really considering the white here, is it the same matte white / black as the F6Bs?
For the C8C or the C8C+BX8C ?Based on the previously released measurements, we have made further adjustments to the system settings to achieve improved performance.
In the vertical directivity, the 100–300 Hz region—where the dispersion had previously been slightly broader—has now been better controlled, resulting in a cleaner and more ideal vertical directivity pattern.
We will share the updated results once they are available, and the previously published measurements will be revised accordingly.
Is the black matte?The color tone is the same as the F6Bs. However, the texture will be smoother.
I have the F6Bs in black, its very matte and non reflectiveIs the black matte?
I prefer the speakers to disappear in the dark and not reflect the projector's light.
I think the Genelec Speaker Placement Guide should work for cardioid speaker too. So any distance from 40-60cm should null the FR above the omnidirectional bassfrequence into the cardioid response, so that this "null" is less relevant?Any recommendations on placement distance from back and side walls? Also recommended listening distance?
C8C+BX8C is already very good in that range. C8C use some improvement, but the design constraints are higher.
Congrats to @AsciLab for this one of a kind speaker!
Looks just great in terms of design, measurements etc!
One question fell more or less immediately in my mind:
Have you thought about double the bass modul and stack the second one on top of the C8C? (Refer to SteinMusic Bobby S-M-L). Would this bring some additional improvements in terms of beamwidth especially in vertical axis?
The max Output of the bass driver would maybe improve as well a bit?
I follow your designs nearly since this thread started and hope your small company is running good in return of your effort!
They will be exactly the same.@AsciLab would the measurements be similar whether we use the analog inputs vs digital inputs for C8C + BX8C?
Overloading the 100W tweeter amp in the FusionAmp is something I did not see coming.
Is the MTON stimulus something from Klippel or from the IEC spec, or your own? What is it exactly?
Apologies for the amount of questions, but it's almost unseen to have speakers perform to this level with a designer willing to engage. Thank you.
