AsciLab @ Purité Audio
The rarest of all things, sunshine in London ( still really cold though)
In retrospect it could have been the porch light.
Best,
THe Cadentia’s are a very beautiful dark Rosewood as per the photograph.
I feel I see some kind of overflow ... (same here, but not for commercial reason).:cool:
We have a couple of rooms on the ground floor of our townhouse dedicated ( more or less ) to audio, ‘partially’ treated with RPG Modex and we have used PSI’s AVAA active absorption.
The number of Hi-Fi shops in the UK has declined dramatically, now it’s either light industrial units out of town or the occasional converted farm building again out of town.
We have all the AsciLab range, to come Roland’s ( GGNTKT) M1s, hopefully D&D 6C and I hear that Mr Yeung might have another ‘Cadentia’ model in the pipeline!
This morning ,we had the C8Cs/A6Bs and F6B all out and playing ( not at the same time ) ,I should have taken a photograph.
The customer brought in his Quad amp which was really heavy, I had forgotten the weight of traditional A/B amps to compare to Fred Boxem’s.
Had to place the F6B’s in front and slightly to one side to accommodate everything.
It is more a question of how far away do you sit, how loudly do you want to play, and how deeply do you wish the bass to extend.
In that case, I would have thought at least the A6B and probably the C8C.
Having said that C6B crossed with sub/subs would probably also be ok.
Personally I like the cardioid response and that you can if you wish add the BX8C at a later time for the ‘ultimate’ speaker.
Keith, you are truly blessed with an embarrassment of riches.
It speaks for your rep within the industry.
Cheers!
C8Cs and the Purifi based A6B/S6B and F6B/C6B are all fabulous speakers, just choose the model that best fits your budget and application.
the C8C is active but I suspect you mean an active version of the A6B?
I don't know, I just started reading this 3D, and I see there are several passive and active models.
Consider that I have several 50-watt amplifiers and a Class D amplifier with IcePower 125 modules.
