Am I correct in thinking that P1 is the best for my room/placement? Only the left side in this file, still playing with the right side. Not a lot of difference in FR, but the RT60 decay seems much more tidy. I believe P1 is Max SPL (cardiod to 100Hz) and P3 is cardiod to 40Hz. Distance from back wall to front baffle is about 38cm, and the manual states:
Recommended distance from rear wall to speaker baffle:
● P1: 100 Hz cardioid / <85 cm
● P2: 50 Hz cardioid / <170 cm
● P3: 40 Hz cardioid / <210 cm
I used
miniDSP's guide for these measurements, if that matters. I realized after the fact I forgot to disable loudness compensation, so there's about 2-3dB extra bass.
Also in the file are C8C by itself, in the BX8C preset mode, and the BX8C by itself because I was curious how they fit together. 4m distance
P1
P3
