The Mofi’s are £2250, a fairer price comparison would be between the Mofi 8 and the Asci A6b.
Really? Well OK! It is “matte” in the U.S. (paint finishes are flat, matte, eggshell, satin, semi-gloss, and gloss) but I guess given the UK spelling, then “matt” works too.In the U.K. non glossy paint is ‘matt’.
I wrote especially "independent of price", so please ignore that. For me the price would be quite similar. But then you may include the A6B also (which is at least 40 % more expensive).The Mofi’s are £2250, a fairer price comparison would be between the Mofi 8 and the Asci A6b.
No, I´m just asking for fun -.- "what would you choose" is not that hard question. All I asked was for opinions regarding the preference of the speaker explicitly without taking the price in consideration. But as It seems to bother you a lot: in Germany there will be a minimum surcharge of 19 % to that price and the mofis are sometimes at sale.Really a £1100 speaker is going to be the same as a £2250 speaker?
How big of a room, how loud do you want to go, will you be using a subwoofer, are you good at integrating a subwoofer into a system, do you have an amp that can highpass the main speakers?C6B or Sourcepoint 8 - what would you choose, independent of the price?
In all fairness, how much is a good subwoofer? If the person doesn't already have one, they would need one with the A6b, correct?The Mofi’s are £2250, a fairer price comparison would be between the Mofi 8 and the Asci A6b.
Yes. It needs a subwoofer if you're looking for a full range listening experienceIn all fairness, how much is a good subwoofer? If the person doesn't already have one, they would need one with the A6b, correct?
Mofi 8 : F3 52hz, F10 35 HzI would be interested in the answer to this question also. I can get a pair of used Sourcepoint 8 for almost the same price. Which to choose?
Also the important for audibility multitone distortion of the C6B seems to be a bit lower:Mofi 8 : F3 52hz, F10 35 Hz
Ascilab C6B : F3 54hz, F10 35 Hz (More smooth response and directivity)
Mofi 8 : Min. Impedance above 50hz 8 Ohms
Ascilab C6B : Min. Impedance above 80hz 2.6 Ohms
View attachment 456536 View attachment 456538
View attachment 456534 View attachment 456535
View attachment 456539 View attachment 456540
Data taken from web.
For tone, moderate listening level, I will go with Ascilab.
Best will be to personally audition both.
regds.
You would also need one with the 8, if we are comparing 8 with C6B?In all fairness, how much is a good subwoofer? If the person doesn't already have one, they would need one with the A6b, correct?
Let´s assume that bass is not a matter, as the speaker gets high passed anyway.How big of a room, how loud do you want to go, will you be using a subwoofer, are you good at integrating a subwoofer into a system, do you have an amp that can highpass the main speakers?
More data, although I also don't know how to interpret them and answer.Could someone please explain why the F6B has a higher score than it's brother C6B? (6.5 vs 5.9)
