- Joined
- May 30, 2024
- Messages
- 760
- Likes
- 5,804
Audiophinics list their restock for the first week of November. Ascilab most likely would prioritise their distributors over their own website.@AsciLab, while you are here, could you please give a quick update on when can we expect the next batch of C6Bs to be done?
Do you have ETA for these?Then you may like our upcoming standing floor design![]()
Welcome to ASR!I have a Denon x3800h. Would that be enough to drive a pair of C6Bs, or should I consider getting a separate amp for these?
Welcome to ASR!
The C6B has a low 84-85 dB @ 2.83 V sensitivity and a very low impedance (below 4 Ω from 90 - 600 Hz and below 3 Ω from 110 - 450 Hz), and will likely be a difficult load for the typical AVR.
I'm current running a 3.1 (2 Q150s and R2 Meta). My plan is to purchase the C6B and move the Q150s to surround speakers instead.Are you running any other speakers (ie, surround) or just the stereo pair?
Will you be using a subwoofer?
How big is your room and how far away from the speakers will you be?
And how loud will you be playing them?
I doubt the Denon X3800H will be able to power the C6B, with its ~3 Ω impedance from 110 - 450 Hz, to its full potential. Let's run some numbers:Thank you for the response, I'm still somewhat new to this hobby and I've found it somewhat confusing what I actually need to power speakers to their full potential.
What is the SPL limit for full bandwidth and limited to 80Hz, 120Hz, and 200Hz? Thanks4ohm rated 100W amps can handle the C6B enough. The woofer in the C6B isn’t for super loud purpose.
Above 80Hz, Around 100dB is the continuous maximum level.What is the SPL limit for full bandwidth and limited to 80Hz, 120Hz, and 200Hz? Thanks
Did you mean now, rather than not?So a WiiM Amp Pro crossed at 80hz with a sub could drive the C6b sufficiently for most people?
After much debate with myself, I'm not close to being set on a pair of C6bs when they are available. I will pair them with an HSU ULS-15 MK2 sub and hopefully drive them with the WiiM Amp Pro.
Alright, I'll goAnyone wish to share feedback on progress of orders placed for F6B / F6Bs directly on AsciLab store since they were listed as available again on ~Sept 15th 2025?
