Ascilab Owners – Ask Questions, Share Feedback
So I ordered the C6Bs. This is the most money I've ever spent on speakers, I would like some advice/tips for the future...
Home theatre / music listening 80%/20%
25 m2 room, about 2 Metre listening distance to MLP.
I dont listen at reference levels, usually -15db - -25db depending.
Denon x1800h AVR
SVS pc2000pro subwoofer so can crossover at 80 to reduce strain on avr for C6Bs.
Using A1 evo acoustica calibrations
I currently have a wharfdale 10.6 and 10.1 speakers 5.1 configuration. I will probably use the ascilab C6Bs as my new fronts and remove the centre channel, running phantom centre, and just use the 10.1s for side surround.
When ascilab comes out with passive floor standers I would think I get those and move the C6bs to the sides and still be phantom centre of the floor standers.
Would the x1800H be enough at that point?
Should I look to get a centre channel or will phantom centre work well enough with these?
Is there another brand I should look at for a centre channel?
Any other advice, things to think about for someone who is just entering the audiophile space in the last year
Denon x1800h AVR
should be enough power with the sub. the c6b have very good vocal intelligibility, I'm using them in a 2.1 system with my lg oled. it's a shame ascilab don't currently offer a center channel. if you have widely spaced front left/right or a big room, a center is helpful to center sound to the screen. My setup doesn't need one because the front left and right are only a few feet apart sitting on the tv stand. I think you'll be very happy with the c6b, for me I don't have to turn on the subtitles anymore unless the movie has a terrible audio track
I received my Ascilab C6B at my Hong Kong apartment around five weeks after placing the order. I was out of town so I’ve just now set them up. Below are my qualitative and quantitative views.
Delivery and Packaging
Delivery was a bit slower than I expected at ~5 weeks, but given this is a new company, I can forgive the delivery timeframe and the information sharing on delivery status. I was probably in the second batch of sales (after ASR’s and Erin’s reviews went out) so I assume Ascilab must have been swamped with a deluge of orders.
The box came delivered to my apartment in Hong Kong in immaculate condition with no marks, dents, or anything to indicate it came all the way from Seoul (I assume they’re made in Seoul in South Korea, but I could be wrong). The speakers are double boxed so given the outside was in a perfect condition, the inside box was also perfect.
I was a bit confused on how to unpackage them but decided to break the seal on the inside box to see how things worked. That was a good call as they’re designed to be removed from the top by grabbing the cloth covering each speaker and pulling them up. You can thank Ascilab for the mini bicep workout. :D
Fit and Finish
Once out of the box, the first thing that struck me was the fit and finish. These look like speakers from a company that has been around for decades rather than a new upstart. Everything looked perfect with no blemishes or bad joints. The speakers are larger and heavier than I expected based on the pictures online, but I assume this was necessary for the immense bass they produce as we’ll see later.
The only potential issue I saw was the rubber isolation material used at the bottom of the speaker. The level of friction gives the impression that they will hold the speaker in place very well, however the softness of the material makes me question if they’ll hold up to someone accidentally rotating the speaker without lifting it up. When I was positioning the speaker, I could feel the material flexing and immediately lifted the speaker up so that it doesn’t rip the isolation material.
The woofer cone finishing ring is taped in place and needs to be removed before use. It’s easy to take off and was no big deal. The ring on one speaker came off when I was taking the tape off, but putting it back is very easy as it’s a magnetic attachment.
One thing that isn’t noticeable in the pictures online is how intricate the tweeter waveguide is. It isn’t a simple conical shape; it’s a variable and complex shape. A very cool detail of the engineering prowess of Ascilab!
I chose the matte black finish and having seen and touched the speaker in real life, if I could go back, I would have chosen the gloss white or gloss black. I think the matte finish is going to pick up lots of dust and is somewhat difficult to clean. It reminds me of Apple’s dark matte finish on the latest Macbooks. It took some effort with a wet cloth to remove my fingerprints from positioning the speaker.
Sound Quality
Some context before sharing my thoughts. The current setup is a Cambridge Audio EVO150 (I believe it uses Hypex NCore modules). The current speakers are Revel F35 2.5-way towers which Amir reviewed here. They are incredible speakers that do everything very well and at a very reasonable price.
The goals I had in changing speakers were as follows:
  • The F35 are way too big for the space I have in Hong Kong. They’re visually big and excite room modes like it’s a Berlin EDM club.
  • The F35 sound very bright in this highly reflective room. Because of the intense humidity in Hong Kong, we have tiled floors and little in the way of absorbent materials.
  • I loved what Ascilab had done in being so transparent with their development of these speakers so I wanted to give them my business and support. If the C6B had not come along, I would have purchased a second-hand set of KEF R3 Meta (I also admire KEF’s approach to R&D and transparency with their users).
Qualitative Sound Quality
Before doing any measurements with REW, I listened to the F35 and then swapped them out for the C6B. I tried my best to position them as close as possible in the same spot so that I could give them a fair chance.
When swapping over to the C6B, three things became readily apparent:
  • The speakers sounded much quieter than the F35. I didn’t want the REW measurements to bias my qualitative impressions, so I rewired the F35 and used an iPhone app to get the output to the same level, which required increasing the volume on the EVO150 by 5db for the C6B.
  • The top end sounded much less intense than the F35 which was a good sign that I may achieve one of my stated goals.
  • The bass was just as intense as the F35, which was something I didn’t expect given the smaller size. In fact, in some songs, I thought the C6B dug deeper, but I wrote in my notes that it was inconclusive and I would need A/B testing if I were to bet money on them digging deeper.
After more careful listening, I had the impression that the sound stage was very wide with a large sweet spot. The F35 are also very good in this regard so I was happy that I didn’t lose any soundstage benefits going with this speaker.
First impressions were very positive and I can imagine anyone setting these up would be very happy with their purchase. Even without taking any measurements, I could tell that they were going to trump the F35 in my room based on how good they sounded. However, the intensity of the bass was surprising and my room would benefit with some Room Correction software like Dirac Live or adjusting the EQ.
Quantitative Sound Quality
Most ASR users will have skipped to this part. Before reading this part, please do visit the intro to the Sound Quality section above as it includes some important points on the positioning, etc.
All measurements were conducted with the amazing and free REW software (thank you John!), UMIK-1 and Cambridge Audio EVO150 amplifier using AirPlay 2. All measurements were taken using the MMM (Moving Mic Method) with Periodic Pink Noise and at least 60 samples with both L+R speakers playing at the same time.
I conducted three measurements of each setup and ensured they were consistent (they were). I also conducted one measurement of the noise floor to ensure the tested measurements were well above the noise floor. Hong Kong is a very noisy place so it’s impossible to get a perfect environment, so I’ve included the noise floor measurement for transparency.
Revel F35
Ascilab C6B
Noise Floor
Revel F35 vs. Ascilab C6B vs. Noise Floor (Hong Kong Apartment)
Conclusion
As expected from the measurements we’ve seen online, the Ascilab C6B delivers on its promises. The speakers have excellent in-room measurements and can keep pace with my much larger Revel F35. I didn’t go above 100db for too long, but I didn’t notice anything unusual in either speaker at what I consider to be high volumes for an apartment.
IMO, Ascilab is leaving some money on the table with these speakers and I would not be surprised if we see price increases over time. I’ve never seen a company sell a premium product at a low price for long. They could increase prices 25% and still have a fantastic value for money offering. I’m now wondering how much better the Purifi model will be…
As I've been writing this enormously long post, I've been listening to a variety of music at rather loud volumes and I'm loving these speakers more and more. They've tamed the brightness I had in the room and this makes listening to music so much more enjoyable! I hope the above provides some insight; I’d be happy to answer any questions you may have.
Fit and Finish
Sound Quality
Revel F35
Ascilab C6B
Noise Floor
Conclusion
great review! thanks for sharing!
Fit and Finish
Sound Quality
Revel F35
Ascilab C6B
Noise Floor
Conclusion
Much appreciated. Thank you for your time and effort in posting this.
Really cool to see how both the Revel F35 and AsciLab spin data's in-room estimate and slope is quite applicable above ~700hz. (except maybe the Revel's ~2dB rise 1.2 - 1.5k). Changing from such good speakers to begin with, great to hear the positive experience of the AsciLab in your space - though I guess you're left with similar bass characteristics to perhaps manage/correct.
I have been wondering whether with close proximity wall-reinforcement, and adding sub(s) and with measurements and room-corrective eq, would the F6Bs sealed model actually do really well down to ~80hz?
I assume the Spin/Klippel Estimated in-room response isn't showing what close-proximity boundary reinforcement would do. I suppose we expect the bass will vary greatly in-room anyway.
The passive radiator models may be more versatile in general, and is still the model I am interested in getting.
Enjoy your speakers and more importantly, the sound and music.
I took the Kippel measurements from Erin's site and overlaid them with my real in-room measurements. It's remarkable how accurate the Kippel estimate is!
Nice. Yeah, spot on above 1k! Good to see your room makes for a tilted downslope. It's also pretty remarkable how much difference there is in the low end! I'd be more than ok with this much extra, free energy down there, which could readily be flattened with eq, if one desired.
I'm guessing your purple line is psychoacoustic smoothed? Wonder if the 50hz peak in earlier measurements is maybe 50hz power anomaly?
It's remarkable to see how low they play in a small room, in this configuration they don't seem to need a subwoofer indeed, you won't feel anything's lacking at reasonable levels.
to quote Pink Floyd from "The Wall" - "Get 'em up against the wall"
Free bass. not to be confused with the crack cocaine kind.
I got my vibron footers today and implemented my plan to flip the c6b upside down so the tweeters are closer to ear height, and I taped the speaker wires to the side so they don't touch the passive radiators. used that non marking blue painters tape. I've noticed a slight boominess, I think from the passive radiators being so close to the wall, vs my other speakers which have front bass reflex ports. I might have to go back to using my minidsp as my frontend with a highpass on the main speakers instead of just controlling my passive subwoofer. need to do some more listening and measuring first.
I think that looks cool, and your last photo catches the light to highlight the detailed curves of the waveguide.
Getting eq involved for your low end will surely give good results whilst maintaining the advantages of having them close to the wall.
Got a measurement mic? Apparently for low end, any mic and frequency analysis is likely to be written suitable for developing eq filters.
long story short I ended up putting my minidsp flex with dirac back as my entire frontend preamp/dac and reran dirac with my umik1 with the cross spectrum 90 degree calibration file. it completely removed the bass boom and does sound better than having my fancy dac control everything with the minidsp only running my passive subwoofer.
When JBL HDI-1600's are like USD $2000+, the value to performance is very, uh, worse than AsciLab, particularly F6B. But if you can get ex-demo HDI-1600s with warranty for ~$830 USD, might it start to be a more valid consideration?
spinorama comparisons indicate the HDI really should be rather good, and might sound fairly similar (with eq). HDI's have wider dispersion, less tilt, less well behaved vertical dispersion. and they don't have a 1khz crossover!
I'm still more interested in the F6B, including the 1khz crossover, and figure they are more likely to behave well in a pretty small room. And I can probably be patient.
I guess it's just a rather good price and limited offer for the HDI-1600s.
Thinking out loud...
My C6B in white arrived this week.
They look and - more importantly - sound as good as the reviews :p even with my budget 250 Euro WiiM amp.
However, after careful consideration, I have decided to keep my main hifi system only as I hardly ever listen to anything else.
So the C6B are for sale (in the sales section)
@AsciLab Please improve deliveries for europe, I mean order now and wait for at least 2.5 months for a pair of black c6b is just too long...
New C6B owner here. As many others, I decided to buy them thanks to Erin's review.
My observations after a few days (be aware Elac DBR62 have been my daily speakers for almost 5 years)
Overall tonality neutral as expected, nothing jumped at me when I switched from Elac. The bass between 30-40hz is stronger than Elac, but I would not say it is more detailed or "faster". Interestingly both stop sharp at 30hz, I hoped C6B would faintly play few tones lower. I need to say that I placed them exactly at the same spot as Elacs and use the same EQ for room modes. I should be able to make the bass a bit tighter with different placing (not likely to happen), or EQ adjustment (maybe).
The midrange is very clean, definitely a step up from Elac. The treble though, I don't know what to think yet. Elac is maybe a bit hotter, but most of the time I don't notice, I got used to it (after finding the right toe-in). C6B is more neutral, but the reproduction is different, especially cymbals, they sound thin (or sharp, but not in offensive way) and kind of artificial. Normally I don't care about that register too much, but it draws my attention now, notably with jazz/rock. This is my first experience with metal tweeter, maybe I just need to get used to it, I'll see.
In terms of look and feel, slightly disappointed. I have matte black version, I expected the finish to be smooth, but it is a bit grainy and you can feel tiny paint specks. It is a "fingerprint magnet" and it takes effort to clean. There is a thin foam glued to the bottom of the speaker, I would prefer to have the foam/isolation on the stand rather than speaker. The cover ring around the woofer protrudes a bit. But yeah, nitpicking, it looks fine, just doesn't ooze premium.
Hey thanks for the feedback, what amp do you use?
