AsciLab F6Bs Speaker Review
Rate this speaker:
    Votes: 2 0.5%
    Votes: 8 2.0%
    Votes: 63 15.8%
    Votes: 326 81.7%
I just got my pair which will go outside on a covered deck replacing some Revel M55XC that never sounded good, in part because they had to be mounted high and on their side. The F6Bs vesa mount let's me mount lower them and point down, which should help imaging a lot. Gonna run them with a wiim amp. Might have to dig out an old mini subwoofer and help the bass a bit.
Man, an awesome speaker that I own but why outside on a covered deck? Are you in very low moisture area? The bass driver is a paper cone and the enclosure does not seem too durable, even for indoors. Why not at least a bookshelf with different speaker cone and surround material?
Yeah that's a risk and no not ultra dry. Durability will be fine but the paper cone - we shall see! Perhaps there were better choices, but not many in that range.
I thought about it and you are right. I shouldn't put those out there. I'm returning then.
Good call. Hope you can sell them
To another member. They really are fantastic speakers, just made for indoors.
After much experimentation this is the EQ profile (minus room correction ofc) that led to these speakers sounding truly fantastic; a PK to fix the 500hz bump and a 12db high pass at 100hz which, combined with the speakers own rolloff, leads to a really tidy 100hz 24db rolloff for crossover with sub
I also did a little hack to create a crossover even though I have a stereo dac without seperate sub output; the 12db high pass is going to the sub too but I use the SVS eq to counteract that and bring it back up to flat (at least, flat to 35hz, -3db at 30hz then sharply rolling off below but that suits my usage case anyway), below illustrates the filters I dialed into the SVS counteracting the high pass (i then low pass the SVS 100hz 24db in the app to complete the crossover, positive polarity as its a 4th order crossover)
I'm still unsure if this hack is genius or stupid but either way it sounds incredible and the ascilabs definitely benefit a lot from that high pass filter
Good show! How many positions did you measure in?
I can't wait for Tested to get more stock. Supporting ASR and getting a premo set of speakers. Win/win
Didn’t include my own measurements there as they’re purely for room correction and only useful for me, it’s applied on top of the above
The top measurement is the speakers on-axis from the Klippel measurements in the review (thanks Amir :) )
The bottom measurement is just a straight line with the filters applied to illustrate what’s happening to the signal the subwoofer is playing
Lol, that explains it, The question behind my question was me wondering why the second graph didn't have any room effects. But I didn't want to be one those "you're room correcting wrong" folks. Yucking peoples yum is no fun.
