AsciLab F6Bs Speaker Review
Rate this speaker:
    Votes: 2 0.5%
    Votes: 8 2.1%
    Votes: 60 15.5%
    Votes: 317 81.9%
Does anyone have any recommendations for an all-in-one integrated receiver to pair with the F6Bs's?
For I/O I'm looking for something with at least two inputs, one being phono for vinyl, and I will only need one set of speaker outs (not RCA). Adedicated sub-out would be nice, but is not essential. As far as functions, I am hoping to find something with bluetooth and a wireless remote.
I am hoping to spend a max of $200 (super down to buy used) without massively bottlenecking my setup. My alternative plan was to get a Fosi amp and a Wiim, but thought I might be able to get away with spending a little bit less by using an integrated receiver.
Thanks!
Amir's subjective evaluation of the two Asciilab speakers is somewhat lukewarm compared to the previous Grimm report. Is it because there is no comparison between them, price not considered?
I'll admit, I hadn't read the GRIMM audio review until you mentioned it but I have to agree that although this is a very favorable comment about the F6B:
"Overall, the response was delightful. Every reference track sounded wonderful and belied the size and cost of this speaker."
It is no where near this from the GRIMM speaker:
" I could sit there and listen for hours and hours. Indeed I did fair amount of that without either our dogs or my wife complaining! "
Am I incorrect in thinking that we've been told over and over that measurement numbers don't lie and we can pick a speaker based those? Because, based on numbers, both of these speakers should get the second comment.
While I appreciate technical excellence, when I'm shopping for something to listen to, I want the 'could listen for hours and hours' speaker. I haven't gone through the other reviews to compare dollars to subjective comments but, is there a price point where it just isn't possible to achieve that sound? Is it just an issue that most reviewers like listening at higher volume levels and smaller speakers can't fulfill that for them? Or is there something else missing?
Are we forever trapped in the "for its size and price" condition being put on all subjective raves about smaller and cheaper speakers?
How expensive do you have to go to get to the "I just didn't want to stop listening" speaker?
Hard to compare the two... One has a built in sub, that far exceeds the bass quantity and extension. Without controlling for this, level matching, his subjective comparison can't be fully relied upon.
Maybe if you removed the sub from Grimm you could compare them. Otherwise, they are not in the same class as due to high pass, the F6Bs doesn't produce any sub-bass.
This is a review, detailed measurements, EQ and listening test of AsciLab F6Bs bookshelf/surround speaker. It was sent to me by the company and costs US $575 for a pair.
This is an absolutely gorgeous design! It feels that way as well with a solid cabinet that is neither too light, nor too heavy. I didn't know if the grill over the woofer came off so left it alone. Back side shows that it is a sealed speaker:
Company uses Klippel Near-field scanner for testing which as you all know, is the same system I use. I reviewed my measurements with them and they concur with those results.
AsciLab F6Bs Speaker Measurements
As usual, we start with our anechoic frequency response measurements:
Wow, that is one smooth response! Even when a speaker has a flat on axis response, Klippel NFS manages to tease out small variations. Here, there are not other than a gentle "bump" centered around 500 Hz. There is also a slight slope down to the on-axis response. Directivity is heavily managed/controlled as you will see in later graphs.
We can predict the early window reflections:
And as a result, predicted in-room:
Is that bump an issue or not? Will have to examine with listening tests. For now, the slope is somewhat aggressive which should result in a warmer tone.
Near-field measurements show that the woofer is responsible for that small bump:
Horizontal tweeter is exceptionally well controlled, courtesy of good design and that wide waveguide:
It is a bit narrow though as is typically the case so more of a sharp focused soundstage. Directivity shows the same:
This is what we see in well designed professional monitors! Even the vertical is well mannered for a 2-way:
I was worried that F6Bs wouldn't be able to handle the full 96 dBSLP. So went up to 91 initially. Hearing no distortion, I went to my standard 96 dBSPL and it still sounded clean!
Before I forget, sensitive is low as is the case for sealed enclosures. I estimate about 2 to 3 dB lower than average so better have good amplification.
Impedance shoots sky high as we get down to DC indicating a high pass filter:
So no worries about overdriving the speaker with too much bass.
Waterfall shows the expected time domain elongation due to 500 Hz bump:
Finally, here is the step response which is pretty clean:
AsciLab F6Bs Speaker Listening Tests and EQ:
Initial impression was super positive with a warm "glow" to the music that was a bit apparent. Otherwise, the impression was that of neutrality. I almost stopped there in my analysis but thought I should dial out the bump and see what happens:
I preferred the eq as it lightened up the tonality some, bringing extra clarity. To be sure, I switched to my Revel Salon 2 speakers and they definitely had less of a bass tilt. It is a small change though and preference will likely vary especially if you have some room modes piling on as well.
Sub-bass output was essentially zero. Go up a bit though where techno bass lives and this little speaker puts out solid tones, even causing physical sensation of bass! I did not hear distortion even as I cranked up the volume. And crank I had to do with my 400 watt amplifier. Didn't have to go near max output but did push the volume up. So definitely get a mid to higher power amplifier to drive them.
Closing my eyes and listening to one speaker as I always do, the spatial halo around the speaker was not very large. This was predicted from the directivity plot. So if you are a fan of wide dispersion, then this speaker may not be quite for you. But the reverse is also true of people who want a focused soundstage.
Amazing what happens when you follow audio science and engineering to the max: you get a very reasonably priced, gorgeous speaker that is near perfect objectively. It does things that speaker many multiples of its cost can't. I don't know how AsciLab has managed to optimize so many factors all at once without having to sell the F6Bs for thousands of dollars.
Not only is this speaker excellent for surround duty -- with its screw holes in the back for wall mounting -- but it also makes an excellent monitor or desktop speaker.
It is my pleasure to recommend the AsciLab F6Bs speaker. Don't walk, run to purchase a pair!
I'm glad the same model with and without the port was measured.
Admittedly, this is a passive woofer,but the principle is the same.
We see how much more bass the ported version has and why many manufacturers prefer it.
When is the F6BS over the F6B recommended? Distance from the wall?
My speakers are 5" (12cm) from the wall but my amp has a HPF for the sub.
The shipping wasn’t included before
Have ordered. Never made such an impulsive purchase! Fingers crossed. I'm in the UK and price is $725 though with free shipping. Not sure where $575 comes from that amirm quoted in the review?
Which one did you buy? F6B or F6BS ?
Thanks but I don't like the website layout.
Oddly the Ascilab website actually links to this post when you click the Measurements link. Surely you must live this web site :)
You'll pay 20% VAT on top of that, but you know that. So that'll be about £642 per pair delivered. EDIT: I got my pair of JBL 308p mkii speakers for £300 a pair back in like March 2000, and they don't need a seperate amp to buy either - some sort of comparison but hard to draw value conclusions perhaps, thought an interesting comparison anyway, both speakers have different advantages over the other one. Mind you if you buy the 308p now (I've just looked) and they're about £500 for a pair, so that changes it a bit!
Nope. Didn't like it when I was looking yesterday.
