I have (nearly ) every AsciLsb
model in stock.
model in stock.
Disagree. The product may be difficult to obtain but it does exist.Ascilab is the very definition of a paper launch/vaporware as far as I am concerned. If you can't actually buy the product, it's not a legitimate choice worth considering.
Which one gets more easily physical?Both fantastic, and far more alike than different, just trying to draw some conclusions at this very moment and failing.
I listen to one and think, that’s better then I switch and think that’s better!
KeithView attachment 538540
Choose a good one from the classic "The Sheffield Track & Drum Record"Do you have a specific piece of music in mind that I could use to compare?
Choose the "Drum" side!A ‘record’!
I will hang on.
Just go easy on it, cause...I’ll do it this evening more chance of annoying the neighbours.
Uncalled for. I see no evidence of a vaporwear-type of product intro. What I do see is actual product in the hands of both individual customers and dealers in, albeit, limited amounts due to parts shortages and longer-than expected delivery times.Ascilab is the very definition of a paper launch/vaporware as far as I am concerned. If you can't actually buy the product, it's not a legitimate choice worth considering.
If the pair of BX8Cs with the possible addition of your other subs still do not give you the balanced sound with mid-bass punch you are hoping for it may be necessary to experiment with some adjustments in your listening position, speaker/sub positions and if possible add some room treatment. DSP & REW are more effective when they do not need to work very hard. Your asymmetrical room with "wooden floor on concrete, concrete ceiling, concrete outer walls, ... [and] ... bass room modes 20-30dB high ..." certainly presents some real challenges!Update: I ordered one of last three available pairs of black BX8C from Audiophonics. They should arrive around begin of July.
Thank you fo gently pushing me into this decision![]()
