I’ve had C8Cs installed since Wednesday, first on little <1’ step stools and then on 20” stands. I have a few comments.
The tweeter axis in the first position is slightly low, and in the second it is just below ear height (32” vs. ~35”). I am using RCA cables, WiiM Ultra, and Spotify lossless over WiFi.
I used P1 (minimum latency) presets due to using the speakers for TV sound also. P2 is said to be better hifi sound but I didn’t hear much difference.
First of all, this is a truly outstanding speaker, by far the best I’ve ever heard. It does everything well in mid field (7’ish, 4’ from the front wall, toed in) and I mean it sounds perfect. The bass is so clean, loud, and deep I had to check if room correction or the subwoofer was engaged (neither). In a more typical listening situation (about 1’ from the front wall, 10’ equilateral, no toe) the cardioid pattern cannot fix the room modes miraculously on its own. In my smallish living room, without room correction the bass is prominent when it’s closer to the wall. With WiiM auto correction engaged it is great again and I will be diving into Hypex filters and speaker positioning as the next steps. But based on my experience I recommend if possible keep them a few feet away from the wall and toed in.
I didn’t measure the dB or distortion, but when the speaker is as loud as I can stand I didn’t hear any problem at all. It wasn’t even breathing hard. I have never heard a speaker so well behaved at high volume.
There is zero hiss or audible noise of any kind.
The amp does get warm but it is by no means hot. The warmth is partly because the Hypex algorithm is very sensitive and even inaudible noise will keep it from going into standby. I am still figuring this out in the software and it is a chore. I imagine over time it could affect amp life.
Hypex Filter Designer software is unfortunately a requirement. Amir alludes to it above, but it is not optimal. It’s really only acceptable for audio geeks - think REW. It uses a DOS-like interface, is PC-only, and uses only a (supplied) USB-mini cable. For an amp of this reputation and cost I expected much better, like the terrific WiiM interface. After some initial head-scratching it is working and functional.
Overall I am ecstatic to have these wonderful speakers and to be an early adopter. The C8C sound when placed and tuned to the room is unbelievable.
