Ascilab C8C Active Speaker Review
Rate this speaker:
    Votes: 1 0.3%
    Votes: 7 2.2%
    Votes: 54 16.7%
    Votes: 261 80.8%
@Luken congrats on the C8C. What is your listening distance when mixing on them? Perhaps it's too early to ask :)
Right now, I'm using them at a distance of about 1.2m, but I'll play around a bit over the next few days to see which position works best for me
Ascilab was so kind and installed it during a remote session upon my request. It is a rather complicated update process. Took about 30 minutes if I remember correctly.
I also requested a remote session for an update, but got no reply from them. Didn't see them here for a while either.
@AsciLab , you guys on a prolonged vacation?
Sorry for the late reply to you guys. Recently we are moving our office so have been quite busy days.
If there is someone who wants to update the new firmware, please send an email to this address below.
It would be helpful to install RustDesk in advance that we'll use.
We'll contact one by one.
[email protected]
Does the BX8C frame to connect to the C8C have 4 or 8 mounting holes? I noticed one of my speakers has 4 holes and the other has 8.
My C8C (first batch) has 8 mounting holes at the bottom. The original foam rubber at the bottom had 8 holes also.
I received replacement silicone rubber pads with only 4 holes, however. Seems that ascilab has implemented a design change?
Regarding the BX8C I don't know as the frames are pre-installed, and I did not remove them. Frames have 8 holes, with a black round sticker to close the opening.
@AsciLab
Happy owner of the C8C´s pair, and I'm using them analogue thru a Adi 2 pro; however, I'm thinking of starting to use it as my main AD/DA Mastering converter, so I will connect the C8Cs with the USB cables provided.
Now, I'm on a Mac m4 and don't want to install Windows emulations, etc.
Can I just connect the USB cables provided to control the volume on the C8Cs? Do I have to connect each speaker with the USB cable or just one speaker?
Need an AES digital cable to connect them from L to the Right.
Thanks in advance
I'm not ascilab but think you cannot send audio to the c8c over usb if that's what you were going to do. There is some volume control there (to maybe set a maximum and there is default) but normally you would do it on the sending side where the aes signal comes from. You go aes in on one of the speakers that comes out of the aes through port that you connect with the other speaker aes in. The usb control app is used (among other things) to tell the speaker it is Left or Right once.
@Taker maybe something like the shiit eitr 2 is helpful here?
Attempted murder. Thank goodness I was listening at moderate volume.
But I did see the woofers vibrate. And I decided to download the track and run that section through a spectrum analyser.
Who leaves a 19Hz at such high volume in a music track?
shiit eitr 2
Totally yes.
I have to think about what to do
wh
What's the track/artist?
shiit eitr 2
Totally yes.
So your speakers are now set to L+R when you connect aes. Just saying. Ask someone for a windows laptop or something. You won't need it for too long ;-)
Didn't buy it yet.
Just asking questions to see where to go
The C8C accepts either digital or analogue ‘in’. I used to use an RME ADI pro to send and attenuate a digital signal, recently Eversolo’s T8 equally capable.
Maybe who didn't hear it in on their own speakers and thus found it not bothering. :D Would like to know the source of that signal.
Worst case to your units would probably have been the clipping indicators turn on.
