Additional question: Is the firmware update only affecting C8C frequency response and directivity in standalone mode (P1 and P2) or does it also have an effect on C8C + BX8C (P3) configuration?@AsciLab are there any news re the firmware updates that were mentioned a while back already? I remember there were issues with HFD so I was wondering if these were fixed so we can do the updates ourselves.
Sorry if this has been mentioned somewhere else already.
C8C + BX8C in a 18sq/m room? That's absolutely overkill in my opinion.Yeah, there is no absorption on the front wall behind the 8C, but in the corners on the sides of the speakers i have stacked bass traps floor to ceiling (80x80cm diametre) to catch the low frequencies in the room (especially the sub region), because they are cardioid only down to 100hz.
And on the back wall corners i have 50x50cm bass traps floor to ceiling + 10cm thick panels all over the room to control the reverbation.
Soon i am planning to put 20cm thick cloud over my head.
Wondering if C8C + BX8C need that much treatment for optimal performance in a room.. but as far as I know acoustic absorption is never too much in a medium sized room of 18 sq/m like mine.
Not necessarily. It is about directivity, not about max. SPL.C8C + BX8C in a 18sq/m room? That's absolutely overkill in my opinion.
Listening distance is 1,5m.Not necessarily. It is about directivity, not about max. SPL.
The same logic (uniformity vs. max. SPL) applies to using multiple subwoofers in small rooms.
That is the recommended minimum. Too near for my taste.Listening distance is 1,5m.
fixed and non-automatic input, even the time in minutes can be changedHello,
I have a quick question about how the C8C works.
At VERY low volumes, it tends to go into standby mode!
Is there a setting to prevent this?
Thanks
Yes exactly, as far as i understood BX8C makes the whole combo sound better, not just louder. And the cardioid bass is extended down to 40hz, which means it is much more precise, direct and tight.Not necessarily. It is about directivity, not about max. SPL.
I can extend the listening distance to 2 meters.Listening distance is 1,5m.
Low volume x duration, or switch off standby mode.Hello,
Thanks
I got it easily by requesting a remote support session. Support offered same day, I postponed to a few days later to fit my schedule.@AsciLab are there any news re the firmware updates that were mentioned a while back already? I remember there were issues with HFD so I was wondering if these were fixed so we can do the updates ourselves.
Mine's 15m2. Sounds fine, clarity more than volume.C8C + BX8C in a 18sq/m room? That's absolutely overkill in my opinion.
It's the only distance ~9 ft. I had the C8Cs on a desk, while I was waiting for the BX8Cs and anything less than ~5 ft wasn't great, but I didn't spend a lot of time adjusting them, as it was only temporary.Sounds great!
What is the minimum distance you like to listen to them before losing phantom centre and width starts to sound artificial?
+1@AsciLab any issue having different firmware versions in C8C (1.0) and BX8C (1.1)
I assume you have to dial in the same PEQ in both modules, at least until the highest frequency the BX8C handles.Also with using PEQ in the plate amps to correct room modes - do we do it in the BX8C or C8C amp or both?
There is no issue with combining V1.0 and V1.1.@AsciLab any issue having different firmware versions in C8C (1.0) and BX8C (1.1)
