- Joined
- Jan 7, 2020
- Messages
- 1,582
- Likes
- 2,249
Genelec makes it easy to intrgrate subs with GLM - but you have to use Genelec subs which are expensive and ugly
I used to believe multiple subs in diffetent locations was better but I have come to believe full range or tightly co- located subs are generally better. At the end of the day you are trading time domain accuacy, a larger sweet spot, and much simpler integration you get with full range speakers for possible smoother FR (assuming the potentially better sub locations are actually available for use) for spliiting subs from mains.
If you can fit them well space-wise, then go for it. With the C8Cs you wont really need any additional software if you are not doing subwoofer integration, just measure with REW and apply correction in the DSP menu of the speaker where needed. Or use OCA's Gsonic for correction, which is free for Stereo and very positively reviewed here.Thank you guys, your input is very much appreciated.
I’m leaning toward keeping the setup simple, meaning no added cost or complexity from subwoofers. I’ll focus on managing (lessen) the inevitable peaks and nulls in the 0–300 Hz range through careful speaker placement and targeted absorption. I'm aware that the absorption I'm able to fit in my room won't be effective at really low frequencies.
The sweet spot doesn’t need to be wide for my use case, since this is strictly for one-guy mixing at a static spot.
I only need about 85–90 dB SPL maximum at the listening position.
I will most likely be using a room correction system like Dirac Live or IKM ARC Studio hardware. I know that it will eat into the active monitor's headroom in case of nulls/cancellations, so the goal is to minimize variations in FR through many small improvements and adjustments.
The monitors will be placed on stands behind my small desk, with a listening distance of about 1.3 meters and most likely at an asymmetrical distance floor/ceiling. There will be desk and floor bounce/reflections, but what can you do.
I’m hoping the C8C’s cardioid behavior will smooth out the in-room response at the listening position, especially in the 150–500 Hz region, reducing how much active correction is needed there.
If Genelec has made one thing clear, looks and SO factor are a far distance concern.Genelec makes it easy to intrgrate subs with GLM - but you have to use Genelec subs which are expensive and ugly
I am not using it myself (I have them integrated into a multichannel system with Dirac), but you can take a look at the manual of the C8Cs posted earlier here:@TheKoC, I already have and use the IKM ARC Studio. How many dB can you gain or reduce in the C8C DSP and what is the width (Q) range for each point? How many eq points are available?
C8C Starter guide here,
KeithAsciLab Manual - Google Drive
drive.google.com
The Hypex FusionAmp EQ gives you@TheKoC, I already have and use the IKM ARC Studio. How many dB can you gain or reduce in the C8C DSP and what is the width (Q) range for each point? How many eq points are available?
@markstein was quicker.The Hypex FusionAmp EQ gives you
9 EQs (either PEQ or low shelf or high shelf):
Q = 0.1 ... 20
Gain = -15.9 ... +15.9dB
F = 10 ... 50kHz
smart guys with their own klippel nfs hit differenthow new to the speaker design game Ascilab is
If cost is not a concern you can never have too much bass or too much headroom, especially when using DSP to smooth out room modes.– setting aside the additional cost –
Very interesting speakers and very interesting thread (and the "sister" thread about V1.1) as well
Given the excellent bass reproduction of the C8C, I’m not sure, however – setting aside the additional cost – whether the BX8C really makes that much sense in small and medium-sized rooms; at 136 cm tall, they’re proper floorstanding speakers, which aren’t that easy to fit into many rooms (I speak from personal experience; my Kudos Titan 808s are truly massive, even though they’re ‘only’ 117 cm tall).
On that note, another question:
According to the Ascilab manual, the centre of the C8C – measured 28 cm from the bottom of the speaker cabinet – should be horizontally at ear level.
If I add the BX8C, which is 80 cm high, that would mean my ears would have to be about 108 cm from the floor.
That doesn’t really make sense to me: sitting in an armchair or on a sofa – and I’m not short – I can barely reach 108 cm “ear height”.
Final question: What is the ideal speaker stand for the C8C, if it’s not going to be the BX8C, which is very expensive for a stand?
Same here.If you do the calculation, then at 2.5 m and for a position within 5 degree of the tweeter height, you can position your head within a 44 cm window. The reverse is also true, if you have a set ear height, you can position the tweeter within 44 cm and still be within that 5 degree cone.
As for bass, it all depends on room gain, for my room I have bass extension down to 20 Hz at any listening volume I consider reasonable for 99.99% of musical content. I think the only exceptions would be some of the tracks Amir shared with load and loads sub bass, but a very quiet track otherwise, and even then it's perfectly fine at a comfortable short term listening volume/
Your calculation is correct, ofc.If you do the calculation, then at 2.5 m and for a position within 5 degree of the tweeter height, you can position your head within a 44 cm window. The reverse is also true, if you have a set ear height, you can position the tweeter within 44 cm and still be within that 5 degree cone.
I used Dayton Audio 20” stands. They put the tweeter about 2” above my ear level when seated. They are IMO overpriced (like all speaker stands?) and utilitarian but they do the trick.Very interesting speakers and very interesting thread (and the "sister" thread about V1.1) as well
Yes, it's not all the same. Multi-subs certainly cannot substitute what the BX8C is intended to do but could always be an addition. This reminds me of the Genelec 2x 8361A + 2x W371A + 1x 7380A dream-setup.[...]
I have to admit I don’t understand the current fashion of multiple subs. Tuning one sub is much easier than multiples and much, much easier for physical space requirements.
The BX8C in my understanding does contribute some bass but is targeted mostly at creating cardioid radiation of midbass to match the C8C’s upper bass and higher frequencies.
