Ascilab C8C Active Speaker Review
Rate this speaker:
    Votes: 1 0.3%
    Votes: 7 2.3%
    Votes: 54 17.5%
    Votes: 247 79.9%
Yes I missed that announcement too. Any further info would be welcome.
$28K is a pretty high end price. I suspect it will be challenging to maintain focus from $0.725K/pair all the way to $28K/pair/.
As @staticV3 states they are in the original road map, but the C8C on their own are superb, with the BX8C underneath they are going to be well, even better!
Perhaps someone can answer this question for me. What is causing the far-off axis loud spots around 500hz-1khz?
AsciLab C8C speakers active 3-way cardioid speaker hypex horizontal directivity dsp measurement.png
We’re trying to get less lobbing error in the same form factor by setting new preset.
Is that why Amir measures a rise around 700-800 Hz in the response of the left woofer?
I thought measuring near field would eliminate that rise.
AsciLab C8C speakers active 3-way cardioid speaker hypex frequency response driver measurement.png
On purpose, I think.
I'm not sure whether that makes more sense, my question is whether the rise is related to the lobbing error.
I don't doubt that the side woofer and its response is fulfilling the purpose Ascilab wants it to fulfil.
Is it really an issue though? I have not seen it show up in any of my in room measurements.
Though it was already attenuated -6 to 9dB, we found the way to reduce the lobbing more without any side effects. Only a little bit wider beam width as you see though the difference is less than 5 deg.
Yes it is “on purpose”. Sorry for the typo.
The side woofer doesn’t produce clean curve which makes “not” clean directivity.
