- Joined
- Sep 16, 2019
- Messages
- 1,370
- Likes
- 3,232
S400mkII is quite totally different case. It has 3-4 dB more relative power at 200-1400 Hz than C8C so it's definitely less thin with the same on-axis balancing.
Makes for an interesting discussion. Most normal forward firing loudspeakers that feature some form of controlled directivity, do so only between the edge of the mid/woofer passband and the working range of the tweeter. The result is a polar which explodes in the midrange, and so the sidewall reflections, which I'd argue are the most important, always have a certain amount of coloration. In that respect I much prefer a much more constant directivity down to the modal range. I can't say thin sounding is how I would describe it, but I can only speak for myself in my own room which is small and on the damped side. It would be interesting to test a speaker which features a slightly downward tilt its horizontal behaviour but still in a linear fashion, without compromising the on-axis. I guess it could be done with either a well designed wide baffle or a variation of resistance slots.
