spoutnik12
- Joined
- Oct 5, 2025
- Messages
- 5
- Likes
- 30
Why not! But what is exactly SNS?Can we use your pics in SNS?
Here some real world pictures of that setup if that might help anyone chose this color (or not!)
social mediaWhy not! But what is exactly SNS?
@spoutnik12
in my room that has very little concern for aesthetics, I'm just using those basic studio monitor adjustable height stands, but with the bits cut so they can go low enough if required. They have strips of similar material as what's on the bottom of the AsciLab on the platform. Grippy. not gonna slide with sound.@MarkS correct, they are indeed Q acoustics concept 20 I bought quite some time ago. Not sure if the proportions are still OK with the F6B since they are singnificantly bigger than my previous pair.
But as pointed out by @jEDGEc0m the glass support gives kind of an "airy" feel.
One thing that I also knew from this forum and that I experienced is that the speakers have a layer of rubber/silicone on the bottom. This makes "anchoring" them to the stands quite difficult (there is also no holes for screws). Previously I just used some pattafix (blutac in the US if I am not wrong) on the hard bottom of the cabinet that made a good job preventing accidental tipping. Now I just instructed my daughter to be careful (I guess not as efficient as the Pattafix!!).
There will be a little diffraction in tweeter range, but you won’t notice it. I recommend to use the grille with F6B because the woofer isn’t coated so it can be easy to be damaged from sharp things or liquid.@AsciLab, the woofer is mounted into F6B enclosure with a 90 degree border around it but C6B has a sort of rounded ring around it's woofer.
Is there any issues (sound reflection) if F6B used with or without it's grill?
Aluminum is more durable than paper.Isn't the ceramic coated C6B woofer equally if not more susceptible to damage from sharp things or from poking juvenile fingers? C6B doesn't come with a grill.
You seem to be boosting frequencies that are below what these speakers are designed to comfortably output, e.g. at 37Hz and 56Hz (if it is the latter EQ list you are using), and 37Hz is in subwoofer territory (unless of course you do have a sub and are high passing the mains).Some further impressions (yeah I told I had no objective way of measuring "sound"...).
I ran the Wiim "roomfit" correction using my Ipad and what a difference it made. The main difference I can "feel" is in the lows ! It goes so low in the "very lows". Seems it's not even a sound but some vibration you can feel in your chest. I never felt that with my previous speakers. According to my correction graph it removes some of that bass but actually adds some in the very low 44-49hz which I guess is what I can "feel".
Here the graph in case you want to see how bad my living room Sounds!
I applied the spinorama EQ before the room correction test:
