Hello guys. Thanks for watching our tiny son. and Thanks to
@Nuyes.
I've seen some of you concern about very low impedance at midbass range and steep phase at bass range.
It was also my concern too while designing crossover. It is 2-way and has LR4 XO at 1.1kHz. To get exactly matched phase each drivers at XO point and not to suck out midbass, We had to use quite large cap and low DCR air core coil. That's the main factor for the C5B having that low impedance.
We had another way to use 8ohm version woofer.
But then it must has -3dB lowered sensitivity. It is 80dB/2.83V@1M. We didn't want to design that low sensitivity.
And also bass alignment of 8ohm version doesn't fit to our purpose size.
So we chose 4ohm version though it has quite low minimum impedance.
Actually we don't concern about that now. Because it is only 5", 50W Power handling driver.
Even though it has hard to drive impedance, you don't really need much power.
If your amp is lack of power to drive this speaker, Please. There are a lot of great amps these days.
I want to share a practical result by 2 different amps. One is Topping PA5ii, and the other one is NAD C298(Purifi amp).
I measured with STEP Sine Sweep from 1V to 20V, 1V step.
20V is 100W at 4 ohm. Yes, I didn't regard about crest factor. but only 20V is pretty high level for this speaker, about 101dB @ 1M.
View attachment 409668View attachment 409669
Now, you can see almost no difference between the two results.
NAD C298 has much high headroom to drive 20V. and PA5ii has Maximum 120W output @ 1%.
Though PA5ii was driven almost max level. There is no significant compression.
View attachment 409670View attachment 409671
And here is distortion at 20V.
It would be more important to concern speaker output capability before Amp output.
So, Yes. I also concerned about low impedance to while designing.
But in practical situation, don't have to worry about that.
You only need to worry about something like 2ohm 1000W subwoofer. And yes again, We won't do that when we design subwoofer.
C5B is our entry model. There will be some reviews of our bigger models C6B and A6B using Purifi woofer.
Please stay tuned. Nuyes is preparing a lot of datas. Thanks for watching us again.
