Sokel
- Joined
- Sep 8, 2021
- Messages
- 11,387
- Likes
- 12,513
If its low distortion what you're after, any sub won't do it equally.Knowing that even a SOTA speaker such as the A6B struggles with sub base (below 60hz) does it not follow that, irrespective of what speakers you have, ALL stereo systems should incorporate a high pass filter on the mains together with a sub, especially if you want to achieve an SPL inexcess of say 90db with 100db peaks.
I'm using a 100W Wiim Amp Ultra with Room Fit ($550) to drive a pair of B&W AM01 ($600) external speakers with an old second hand 112" Velodyne sub ($200) crossed over at 70 db within the Wiim App. The system is outside on my patio, with a roof over and two open sides, and to my ears it sounds wonderful.
The high pass filter not only saves the speakers from over excursion and opens up the midrange, but also reduces the load on the amp, as it works hardest to produce sub base. I would imagine it would contribute to the systems longetivity, however, I have no evidence to support that.
It's up to the quality of build, amps and drivers, like anything else.
This thread shows very big differences distortion-wise for example:
I measured 10 subwoofers.
Hi, it's been a while! I would like to thank the people who made this project possible on a scale never before imagined in South Korea. I measured a total of 10 subwoofers, including my own DIY subwoofer(L26RO4Y), and measured them to the CEA-2010 standard using a Klippel TBM module. Below are...
www.audiosciencereview.com
On top of that, sloppy DSP or weak gear can also add tons of low freq distortion as well.
Doable, but not easy.
