Yes. Current version is the final version.
I know ) but you did not answer...
Aluminium Hydroxide or MDF finally ?
mdfI know ) but you did not answer...
. I noted that this speaker is similar to the Radiant Acoustics Clarity 6.2 as far as base reproduction is concerned. Both speakers appear to use the same Purifi woofer
Sideways passive radiator typically make the speaker a bit wider but cancel out the Depp bass shaking of the whole speaker (the Woofer itself may still move the cabinet). Other then that there is no big sonical difference. Sideways passive radiators will occasionally make you grab them in accident when you want to lift the speaker up (knowing from personal experience...).I have a basic speaker design question that more knowledgeable ASR members may be able to answer. I noted that this speaker is similar to the Radiant Acoustics Clarity 6.2 as far as base reproduction is concerned. Both speakers appear to use the same Purifi woofer (I could be mistakes on this point) and both employ two passive radiators rather than a port. However, the Ascilab places the passive radiators on the speaker's sides whereas the Radiant Acoustic speaker places them on the back of the speaker. My question to ASR's readership is, are there any significant consequences or differences in performance related to this design decision? There are Klippel results for both designs so direct comparisons are possible, but I am curious what readers here may think about the design decision on the passive radiator location and what bearing this has on performance.
I don't believe this is correct, the pictures I just looked up show PRs on the sides of the Radiant as well.Radiant Acoustic speaker places them on the back of the speaker
Different Woofer crossover tuning will change sensitivity and maximum output. However the tweeter and mid/hf tuning is also rather different. A6B will probably benefit from more wall distance and have stronger bass then radiant Acoustics and A6B will work better toed in to the listener while Radiant 6.2 seems designed to be toed out a bit from the listener.The Radiant acoustics @-3dB goes down to 62.3hz and @-6db at 39.6Hz
The A6B goes down @-3dB at. 41hz and @-6db at 38.1Hz. Their horizontal and vertical contour are very different as well....
The Radiant is also more expensive $4000 pair VS $3000 pair for the A6B
I asked a few months ago when I saw the change of the spec sheet of A6B and got confirmation that new A6B cabinets were made from MDF.Originally, the A6B used the same cabinet design as the the C6B : the main material = aluminum hydroxide, a substance two to three times more effective at absorbing vibrations than the MDF or HDF typically used.... But I imagine that they use now MDF for effective cost....
Right, I think he may have referred to something like the Buchardt E50 and confused me tooI don't believe this is correct, the pictures I just looked up show PRs on the sides of the Radiant as well.
Yes, but they are just meeting the majority of their customers demands, because consumers don't want to pay more.It's regrettable because that was somewhat of an Ascilab promise. But like the biggest companies, they're trying to cut costs wherever they can...
Yes. And that is well away from any walls (in my measurement setup). So you would get additional room gain plus the contributions from the second speaker.The distortion that Amir mentioned at 96 dB, that's with a single speaker?
No. The driver reaching limits of excursion is a completely different animal sonically than amplifier clipping. And again, for measurements, I used a much more powerful amplifier. In both cases, you see a large excursion from the passive radiators.So the Topping PA 90 reaches his very limit if you want to squeeze out 101 dB of these speakers and may be the reason for the Bass distortions.
A6B brings much easier deployment. Connect it and you are good to go. With two subs, you have to figure out the crossover solution (hardware) and then a lot of measuring and moving subs, etc. You can likely get better dynamics from C6B+sub combo but it would be an enthusiast solution needing fair amount of knowledge and work.C6B + 2 good subs = A6B? Or is there extra goodness in the A6B?
