Ascilab A6B Speaker Review
Rate this speaker:
    Votes: 0 0.0%
    Votes: 5 1.6%
    Votes: 39 12.8%
    Votes: 260 85.5%
We have not experienced the slightest issue with QC with any of the AsciLab models, I haven’t even heard reports of the issues you mention?
Here is atleast 3-4 quality related issues already, 2 speakers, 2 different nut orientations, on the tweeter waveguide the other doesnt have gasket the other does have. Also 2 different types of nuts used in one speaker... Also the other one has 2 braces strengthening the speaker opening, the other doesn't.
‘Nut orientations’?
The missing gasket if it arrived like that from the factory is an issue.
How did you discover ?
‘Nut orientations’?
It all started from the first pair which one of the speakers had 2 missing passive radiator weights.. as i heard some weird sounds through it. Thats when ive started inspecting all the speakers thoroughly but i got sick of sending speaker's back and so im gonna just sell these, and im either looking for s6b or buchardt e50.
On the other hand, i know that im gonna like ascilab sound but on the other hand i just want to have peace of mind that the quality of speakers is gonna hold. Tho im skeptical of e50 high crossover point because with a6b ive been able to move around the room how ever i want which has been a huge plus.
I even tested arendal 1528 bookshelf 8, even tho its 3 way design it sounded way too trebly and thin compared to more neutral sound of ascilab. Also one of the 1528s had an air leak around the midrange speaker grill lol. So i returned them.
This is what I am seeing from the pictures of the tweeter assemblies:
  1. Left has a foam gasket between the tweeter magnet and the waverguide, whereas the right has what looks to be a thinner rubber (?) gasket. You would think that would affect the position of the dome to the waveguide in the front.
  2. Left waveguide has a boss which is cracking (over tightening?). The right seems to have grey plastic reinforcement rings to reduce the chance of the boss cracking possibly.
It will be interesting to hear from AsciiLab about this.
May I ask whereabouts in the world are you?
It is unusual and unfortunate to have two issues.
I haven’t had any reported QC issues here ( UK)
This is the frequency response for my current sub woofer. I have a pair of A6B's on order, and just wondering what I'll be giving up in bass response if I take the subwoofer out of my system. I'm hoping someone who is better at rereading these graphs can tell me. Thanks.
The A6B has the same bass extension but will not be able to play nearly as loud there as a dedicated sub can. So you have to decide between simplicity of just using the A6B by itself vs integrating the sub and have it play at higher levels when it comes to sub-bass frequencies.
This is the frequency response for my current sub woofer. I have a pair of A6B's on order, and just wondering what I'll be giving up in bass response if I take the subwoofer out of my system. I'm hoping someone who is better at rereading these graphs can tell me. Thanks.View attachment 563830
do not remove the sub
Hi Warpenn1, and thanks also to @Trangbar for the careful look at the photos.
First, we’re sorry for the trouble and frustration you’ve experienced.
According to our records, we handled a return and repair for the unit with the passive radiator issue back in March. We haven’t received any emails from you since then. If you did reach out and our reply slipped through, we sincerely apologize. That should not have happened.
On the points raised:
  • Waveguide screw boss: We have found that, in rare cases, a hairline crack can form at the screw boss of the tweeter waveguide. As Trangbar noticed, we have added reinforcement at that point to address it.
  • Foam/rubber gasket: The tape serves as a centering aid for the tweeter. It does not affect the mounting depth or the position of the dome relative to the waveguide.
  • Nuts: Assembly hardware may vary between production batches, and this does not affect performance.
Please email us at [email protected] with your order details, where you purchased, and the photos you shared here. We will review your units directly and make sure this is properly resolved. The same goes for any other owner who sees something similar on their speakers.
Best regards,
AsciLab Team
Best regards,
AsciLab Team
I bought gray ones now, i just got these couple of days ago and i dont know if these are newer batches but the quality has seemed to improve a lot! :) no problems so far! Also does these gray ones use a different paint type? Or has the the paint type changed? I mean these have this nice industrial type of texture on the paint when inspecting closely:)
Also padding has been changed from foam to more solid one
They have a separate gloss coating that is going away in the future. I don't know if the bass paint is different.
I mean gray one has this kind of texture in the paint i can also feel by hand a different kind of than dead flat black had a smooth one if i remember correctly. But I feel like paint job quality has increased, its more even all around, i dont know if its because of gray or quality control has gotten better:)
In general, where are people setting the crossover for A6B's? 60-70 Hz???
60 to 100Hz depending on every factor available
I just run Dirac Art. I think there is a high/low pass in there which I set to 100hz, because that's where it starts distorting at 102 db. Works perfectly with my two SB 2000's.
