Ascend Sierra Luna Duo Center/Main Speaker Review
This is a review and detailed measurements of the Ascend Sierra Luna Duo which the company touts for both center and main application. It is kindly sent by a member for testing. It costs US $798 each.
The Duo as the name indicates, is the doubled up Sierra Luna speaker which I just reviewed:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR center home theater speaker review.jpg
As with its smaller brother, it is a very solid and heavy enclosure for its size. As noted, it can also be put on its side as a center speaker:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR center home theater back panel binding posts ha...jpg
I chose to measure and listen to it in vertical configuration as this configuration usually performs very poorly in horizontal setting.
I performed over 800 measurement which resulted in error rate of less than 1% throughout the range.
Temperature was 61 degrees F. Measurement location is at sea level so you compute the pressure.
Measurements are compliant with latest speaker research into what can predict the speaker preference and is standardized in CEA/CTA-2034 ANSI specifications. Likewise listening tests are performed per research that shows mono listening is much more revealing of differences between speakers than stereo or multichannel.
Reference axis was the tweeter center.
Ascend Sierra Luna Duo Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker is and how it can be used in a room. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR Spinorama CTA-2034 speaker frequency response m...png
And we have flaws coming out of our ear, pun intended! Do we not want transparency when it comes the all important mid-range where the single voice is? Why would anyone want to mess up the recording like this? Yes, there is more bass than the smaller version but the rest of the problems remain. One of the main design failures as with the smaller one is the port:
The larger enclosure did not change the nature of these.
Off-axis response is very poor as well:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR Spinorama CTA-2034 early reflections speaker fr...png
Combination is as bad as one would expect:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR Spinorama CTA-2034 Predicted In-room speaker fr...png
Beam width is good due to small woofers relative to size of the tweeter:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR horizontal beamwidth speaker measurements.png
Colorized version of the same though shows the very uneven response:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR horizontal directivity speaker measurements.png
Vertically the optimal listening angle is razor thin:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR Vertical directivity speaker measurements.png
If you used this speaker horizontally then where the above becomes your horizontal response, you better sit at the axis of tweeter and not move one bit! Never mind about anything else sitting to your left and right.
Really, not much else matters but here they are anyway:
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR impedance and phase speaker measurements.png
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR relative distortion thd measurements.png
Ascend Sierra Luna DUO LCR RIBBON MINI-MONITOR distortion thd measurements.png
Ascend Sierra Luna Duo Speaker Listening Tests
I measured the speaker last night and listened to it today. Not remembering much about the measurement other than port issues, I thought maybe the addition of more bass improves the experience. It did not. What bass there is, is not pleasant. There is less brightness though although there is still plenty of lispy. The worse part was that the speaker ruined my entire audiophile playlist. These are tracks that sound good on majority of speakers (hence the reason they are used at shows and such). Here though, the experience was terrible. I would never use them with this speaker to show off my system. I am sorry abut I can't put words to the total because it is such a mess.
Attempting to fix the issues other than removing the room mode at 100 Hz was not close to making this speaker pleasurable.
To makes sure I was not in a bad mood, I replaced the Luan Duo with Revel M105. Wow, or wow! I was back in heaven enjoying beautiful tonality and clarity. While they are a bit wider, they are actually shorter than the Luna Duo.
The Ascent Sierra Luna Duo is one of the worse measuring and sounding I have tested out of near 100 this year! Company says this about it:
Oh, I can "turn back." You don't even have to ask me. If I had bought these speakers, I would turn around and ship them back. How can the designer be so blind to the objective and subjective faults of this speaker? Has he not measured or heard a properly designed speaker? "Refinement?" In this speaker? You have to be kidding me. "Realistic?" Like to what? An AM radio? So no, I need no "warning" from that tweeter which can't manage a flat response or one that is inline with the rest of the response.
Needless to say, I can not in any form or fashion recommend the Ascend Sierra Luna Duo.
If you are an American citizen, please go and vote. I did yesterday. You can always donate money later: https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
  • Ascend Sierra Luna Duo Spinorama.zip
MZKM
Land O’ Lakes, FL
+$26 shipping, so $824.
That's as a center.
The L/R can only be purchased as a pair for $1624 shipped (I assume sales tax if in California).
The tweeter is rotated for center channel use:
For the 340 model measured a while back, the center version also had a different crossover (it assumed a wider baffle), not sure if they do it for this model too.
3125b
Germany
That's not any better than just one of them ... not much of a surprise.
I doubt turning it over would make much of a difference.
MZKM
Land O’ Lakes, FL
617
Somerville, MA
Ironically, rotating the tweeter will make the off axis worse.
richard12511
MZKM
Land O’ Lakes, FL
Luckily, Amir measured it in the correct tweeter orientation. Imagine the blow back if he had measured in the wrong orientation :oops:
Maybe we can force Amir to rotate it and measure it as a center :p
A shame to such poor performance from a brand with such a great reputation for objective measurements. Perhaps they need to invest in better measurement tools, as so far, the Horizon center is the only one that’s measured well.
Besides the Luna, all the past measured Ascend speakers followed closely to Ascend's own measurements. So, it's really a question of why the Luna is so different.
LTig
Europe
Ah, OK then.
Usually I would ask for a remeasure in the horizontal position but this speaker is so bad it's definitely not worth it to invest one more minute.
chych7
A shame to see such poor performance from a brand with such a great reputation for objective measurements. Perhaps they need to invest in better measurement tools, as so far, the Horizon center is the only one that’s measured well.
"All measurements taken using DRA Lab’s MLSSA system with RCAI, calibrated ACO Pacific 7012 ½” free field measurement microphone with associated pre-amp and power supply and an automated Outline turntable "
Seems like an older measurement method, any info on the accuracy of this vs. Klippel NFS? They measure at 1 m.
BillH
Bedford, MA
MZKM
Land O’ Lakes, FL
Amir, I really do hope your 100th review is one that brings a smile to your face, you deserve better than this.
EVERYONE ELSE, SO WHAT ARE WE DOING TO CELEBRATE 100??????
We already passed 100 if counting the KH80 versions separately.
But as far as reviews go, 98.
100 could either be the F328Be Amir has bought, or maybe that could be 99 and 100 could finally be the Salon2 :p.
He doesn't indicate the key thing which is where the speaker was measured and how he handled low frequency response/reflections. The Mic and software are not important bits. But yes, it does seem like old software and such given the look of the graphs.
Unless anechoic chamber was used (highly doubtful), the accuracy is far, far worse than Klippel NFS.
Shazb0t
NJ
It's really looking like the Lunas are never going in as surrounds for my Ascend system alongside my front three (Sierra Towers & Horizon). I wonder why these were allowed to go forward with such obvious issues?
RMW_NJ
My home theater consists of all Ascend speakers (though I do not have this particular speaker). One of the main reasons I purchased from Ascend was because they were one of the few manufacturers that published measurements. So while I’m not going to turn around and sell everything, it is a bit disappointing to see such huge differences in Amir’s measurements compared to what Ascend has published.
I’ve spoken with Dave Fabrikant a few times, and by all accounts he is a decent guy, so I doubt this is anything intentional...but it has made me realize not all published measurements are created equal.
