They are so darn delicate. The amps are just heavy. These things are like china as far as handling. And I have to take them down two sets of stairs to boot. Will happen one day though.
That Parasound Zamp V3 I sent you is really light (hint )
May be you should install the NFS in your living room and entertain guests in the garage instead.They are so darn delicate. The amps are just heavy. These things are like china as far as handling. And I have to take them down two sets of stairs to boot. Will happen one day though.
UPDATE: Dave confirmed the Mains version is different, it doesn’t have the “Extended Baffle Compensation” and doesn’t rely as heavily on bass reinforcement, and is thus more linear.
Yeah, and even the pictures of the crossovers are the same image file. I stated this in my email and he didn’t address it.Wow this is honestly pretty surprising. I assumed they were identical speakers.
Ascend's site has the exact same on-axis plot for the center and main versions:
http://www.ascendacoustics.com/pages/products/speakers/cmt340c/cmt340cmeas.html
http://www.ascendacoustics.com/pages/products/speakers/cmt340m/cmt340mmeas.html
That's pretty deceptive if true, and could possibly explain why I was never thrilled with these for LCR, although it's also likely due to inherent flaws of horizontal MTMs.
I did measure one of the main speakers to be pretty neutral on-axis, but I never tested the center. Guess I have some homework to do.
Well, yes if course used could be a problem and as well don't forget a manufacturer can cherry pick a speaker to send in. This method doesn't make that as possible. If a used speaker seems not to represent the norm than the manufacturer can surely find a way to step up and send one in.What you highlight is just one a many things Dave says is flawed with your review process and speaker rating. Before Dave posted his evaluation, I thought the process of using used speakers was seriously flawed. You have a uber-expensive analyzer and you test used speakers. This seems bizarre to me. As long as your process is flawed, expect some strong headwinds.
As I see it, use the measurements as a starting point and see the recommendations as a thumbs up to try the speaker out. It is a way to hone in on a couple options through measurements and adjust final choices to taste.I'm trying to understand how one recommends speakers without listening to them. It's clear recommending speakers and trashing certain speakers based on measurements is controversial... Just because you believe in this approach does not mean it is the correct approach.
Apart from the weird distortion spike with the RAAL tweeter, both Ascend products measure exactly as I would expect them to - which is pretty well, by the standards of nice-drivers-on-a-flat-baffle MT and MTM speakers.
MTMs don't work for center channels. They are not a hifi solution unless you are using a big waveguide between the woofers and even then it is bad solution. This one doesn't measure particularly badly or particularly well.
I don't see what all the fuss is about here.
Regarding the outrage over Amir testing used products, I would rather he test units which have been run in for a while, so that any problems that may manifest with time are shown (although I think modern drivers have few of these issues.)
I could take or leave Amir's listening impressions and the preference score, the latter of which ignores output capability (important) to my knowledge, but the data about frequency response and dispersion is a big resource which manufacturers almost never publish. Regarding that data, as I mentioned earlier, what we are seeing with this speaker is exactly as I would expect.
If you aren't designing waveguides or using other directivity control mechanisms such as cardioid or dipole loading this is what the responses basically look like.
Ahender, please let it go. As a fellow Ascend owner, you're making us look like fanatics. I understand wanting the products you own to look good - and the Sierra 2 (and subsequently the 2-EX presumably, which looks like you're purchasing) do pretty decent in the review. Just relax and enjoy your speakers. The data speaks for itself and I don't think even Dave disputes the facts. If you're happy with your purchase, that's what matters - there is no need for external validation.
I've seen that with a few brands lately. In one recent example, I noticed there's an owner of a different brand (not Ascend) who likes to post pages of flowery language that say nothing, but he throws enough "scientific sounding" terms in there to convince the uneducated that he "knows all the science" and has simply found it "lacking, inadequate or wrong" in various ways...so look to his flowery language for "the truth." And boy, do the owners of those speakers ever do that with a vengeance!A lot of times this isn't helped by the cult of personality revolving around certain manufacturers because of company's owners activity on certain forums.
Joseph D'appolito designed the modern MTM implementation, aka the D'appolito array, designs of which you can find today in Usher speakers. While Usher is not a perfect brand by any means, I think raising the tweeter is the only way to implement an MTM without a midrange and still managing to avoid most of the lobing pitfalls of an MTM design. The problem lies in the fact is many manufacturers are simultaneously trying to reduce size and reduce bill of materials.
Not really. Here's how you can visualize this. Measure from the left edge of the left woofer to the right edge of the right woofer. Let's say the woofers aren't 7 inches, but 6, and to be generous, they are right next to each other, with no gap, which is the best case scenario. In the horizontal plane, this is still equivalent to a two way with a 1 inch dome tweeter and a 12 inch woofer, which has laughable directivity matching. It simply is not a hifi solution for the most important speaker in a av setup.
I feel like the RAAL fanboys (of which I am one of), have implicitly imposed the condition that verticality doesn't matter, negating one of the tweeters main flaws.Lol yes. I've owned every Ascend speaker, even the Sierra-EX Diamond with the $7k diamond tweeters. I grew up with Ascend speakers, they were my speakers in high school and college and I spent most of my summer job money on upgrading them after friends introduced the brand to me when I was 14. But I also have an intense interest in the science, and you have to realize at some point you are buying from a business, getting cultish obsessed with a brand will eventually bite you back when you realize it's going to be forever unrequited love that may result in a backstabbing from other cultists when you are no longer needed, just watch the current Administration
In my experience some of the Ascend-RAAL fanboys have crossed into dangerous territory that I usually only see with Dynaudio esotar "soft dome is best!" crazies that you see on AVS. A lot of times this isn't helped by the cult of personality revolving around certain manufacturers because of company's owners activity on certain forums.
For me this is pretty true, the only time I care about how good the speaker sounds is when I am sitting in the MLP. If I move around, I stop caring about how ideal a speaker sounds.
fine point made...if you are critically listening the raal is a great option,once you stand up and move around (doing other things) you aren't critically listening any more... so, the vertical dispersion is not "a thing"...I feel like the RAAL fanboys (of which I am one of), have implicitly imposed the condition that verticality doesn't matter, negating one of the tweeters main flaws.
yes....I don't think of it so much as a flaw, but a tradeoff.
there is this , but as you point out :much of the difference is preference , not as much "performance" , at least that's my understanding...there is limited research that shows vertical reflections add to spaciousness. With a RAAL 64-10 tweeter, you're getting very strong sidewall reflections but much lower ceiling and floor reflections, some might prefer this.
