I purchased a pair of CBM-170SE2 and three HTM-200SE2 to upgrade my music/HT setup. I have only completed some basic testing so far and have used the CBM-170SE2 as surrounds due to odd measurements I got with the HTM-200SE2.
Overall impression of the build quality is that these are very nice for the price point and the binding posts are particularly solid. With the CBM-170SE2 as surrounds, they match quite nicely with the Clements 207di's I'm currently using as mains for music listening. They are also surprisingly compact speakers as I didn't check the dimensions before ordering them.
Here are my on-axis quasi-anechoic measurements with grille:
The situation I found with the HTM-200SE2's is this:
I've been discussing this with David at Ascend Acoustics and just identified the grille as the culprit this morning. I measured similar response with all three HTM-200SE2's.
Without grille it looks like this:
I measured a series of off-axis angles in an attempt to understand the 4k-6kHz behavior observed previously (after having removed the grille for this series of measurements).
So the HTM-200SE2 looks very good with grille off, not so great with grille on. TBD whether modifying the grille can correct this.
I'll be swapping all of these into the HT setup soon (HTM-200SE2 with grille off).
