he has several , I would assume he used more than oneNow, I am wondering which amp did Erin used to do his listening test on the LX.
Well, he said he heard distortion, yes, there is distortion on the data, but there are plenty of other speakers he reviewed with similar distortion that wasn't mentioned. I am not saying there are any motives, I am saying his subjective commentary are also subjective.I also wouldn't take Erin seriously if he would do such claims (which he didn't though), objective data count, the rest is always to be taken with upper cautiousness.
Which I never mentioned, as said above I just care and consider the objective data, not their subjective comments. Also my intervention was about the stated reason of the distortion, not if and how people heared it or not.I am saying his subjective commentary are also subjective
Fair enough. I personally am just looking forward to Dave's writeup of his investigation, strictly for the knowledge of the scientific and engineering findings.Which I never mentioned, as said above I just care and consider the objective data, not their subjective comments. Also my intervention was about the stated reason of the distortion, not if and how people heared it or not.
Same here, love my LX, but the next upgrade is sound is about $6k (elx). I wish they offered a mini tower for around 3.5k.I have been listening to my Sierra LX for 2 years now and am still very happy with them.
As I wrote I disagreed with the statement that such an amp has not sufficient power for such a loudspeaker when in this case the loudspeaker is much earlier the bottleneck, I am sure you know how litte watts of power are needed to reach 96 dB where already MT and compression is an obvious issue. And as you know here in ASR non blinded listening results are not what we just accept as facts.
I agree that the woofer you chose for the LX with its high excursion is one of the better choices but in the end every similar sized 2-way loudspeaker which plays down deep is limited by that, so it is not suitable for very high listening levels or distances especially with music with significant low frequency content. And since you showed some MD of competitors and the compression of the C6B it would be fair to show also their (significantly lower) MDs:
as well of a 3-way which is cheaper than the LX
and since you showed the Buchardt with its Purifi 6.5" midwoofer here is a better implementation with it
This doesn't mean of course the LX is poor but in the end it can also not defy the limitations of physics and its price class, everything is a compromise.
My apologies, I wanted to respond back to you but my daughter had a major head-on car accident last week. Thankfully, she is OK now - shaken up, bruises everywhere, mild concussion, car is totaled. My priorities have been getting her and her daily routine back on track. Absolutely horrifying for a parent - when I saw the car but didn't see her, for a spit second - I thought I lost my daughter. I am definitely more shaken up than her. The good news for us is that the other driver's insurance company has been easy to work with and they are covering everything.
As I already mentioned, if this customer was hearing multi-tone or IM distortion generated from the speaker, it would not have gone away with changing to a more powerful amplifier, it would have gotten worse or stayed the same. This is fact. If you don't understand what causes the MTON distortion seen in Erin's measurement, I can explain a bit now, but I will be fully covering this in detail soon enough.
You had brought up a question about power to reach that level of 96dB at 1 meter - and this is a good point, but to begin the discussion on this, I am going to turn that question around and ask you if you know what the voltage level required to reach that output is. I certainly know, and this is not meant to sound condescending at all - but to check to see if you (and others) actually understand what is being measured in those measurements and how. It is a good starting point.
You brought up the Kef Q concerto's MTON measurements. They achieve lower MTON distortion in Erin's measurement because it is a 3-way speaker, and the mids are handled by the midrange driver, thus the woofer is crossed at much lower frequencies. The MTON distortion we are discussing in these measurements is going be on the upper end of the woofer's natural response.
Ascilab uses a very low crossover point for their tweeter (I believe ~ 1kHz) so that frequency range where the woofer will generate the MTON distortion that we are discussing is primarily being handled by the tweeter.
The very first thing I did, which was about 10 months ago - was to design an LX with a much lower crossover point. That was quite simple, and our Titan tweeter, with a very low Fs of ~800Hz, can easily handle a low crossover point. The MTON distortion results were nearly identical to that of Ascilab (to be honest, slightly better). If we received "distortion" complaints from customers who own LX, or if I had thought Erin's MTON measurement revealed an actual issue - an LX V2 would have been released 9 months ago. However, and I am very serious about this, I am not going to change an extremely well proven design, with a continuing overall satisfaction rate approaching 99%, simply because of one reviewer using a new module from Klippel that, after deep and thorough evaluation of it, has practically no bearing on what someone would actually hear with music. I will soon be covering this in much more detail.
Again, after extremely thorough and deep technical evaluation, had I thought there was an actual issue, LX V2 would already be shipping and this discussion wouldn't exist. This is that fine line between real world experience and listening vs evaluating measurements. CEA-2034 is well proven and has been thoroughly adopted, Klippel's MTON - we are not there yet.
First off, I am relieved to hear your daughter is OK. Car accidents are every parent’s absolute nightmare, and no measurement or speaker debate matters anywhere near as much as her safety. Please take all the time you need to focus on her recovery, there’s zero rush on this discussion. When you're back in work mode, here are my thoughts on the points you raised:My apologies, I wanted to respond back to you but my daughter had a major head-on car accident last week. Thankfully, she is OK now - shaken up, bruises everywhere, mild concussion, car is totaled. My priorities have been getting her and her daily routine back on track. Absolutely horrifying for a parent - when I saw the car but didn't see her, for a spit second - I thought I lost my daughter. I am definitely more shaken up than her. The good news for us is that the other driver's insurance company has been easy to work with and they are covering everything.
Glad to hear you daughter is safe. I remember getting into a car accident when I was a teenager, it scarred me for years.The very first thing I did, which was about 10 months ago - was to design an LX with a much lower crossover point. That was quite simple, and our Titan tweeter, with a very low Fs of ~800Hz, can easily handle a low crossover point. The MTON distortion results were nearly identical to that of Ascilab (to be honest, slightly better). If we received "distortion" complaints from customers who own LX, or if I had thought Erin's MTON measurement revealed an actual issue - an LX V2 would have been released 9 months ago. However, and I am very serious about this, I am not going to change an extremely well proven design, with a continuing overall satisfaction rate approaching 99%, simply because of one reviewer using a new module from Klippel that, after deep and thorough evaluation of it, has practically no bearing on what someone would actually hear with music. I will soon be covering this in much more detail.
Any ideas why Purifi goes to such great lengths in the design of their costly (low distortion) crenelated driver surrounds if multi-tone distortion has irrelevant audible impact with respect to complex music signals?
Thank goodness your daughter is OK. Wishing her a quick, full recovery.
What is the drawback to crossover at a lower frequency? What is it about the LX's proven design that makes it a solid engineering choice over crossing over at a lower frequency?
Thank God your daughter is OK.
You're quite the man to address this topic after that horrifying experience.
Take it easy.......
I know you like a wide soundstage and hence, waveguides hasn't been much a consideration for Ascend.Thank you and excellent question!
Lowering the crossover point and we end up with wider directivity in that frequency range that the tweeter would now be handling compared to the woofer. It is a minor hit to the directivity matching between the woofer and tweeter.
