So after over 2 years, I finally used these with a sub.
Quick recap, I bought these because of my room (bouncy floor), and with the ports 4.5' from the wall I can get F3=28hz. Ports 9.5' off the wall, 50hz (then nothing). Any further out and I lose the port support. With them out I get GREAT imaging and separation, very nice for some jazz and acoustical, but after a couple of days I miss the bass for a lot of music. Pushed back, bass, but I lose depth in the sound stage, and the bass below 40 is pretty distorted. As one would expect from a floor that is a passive radiator.
So, crossed over at 80, and yeah, it sounds very good way out in the room. I might or might not do full on sub integration, try the plugs again maybe, for now I just left the sub where it was for AVR and went 80 for the XO and pretty much left it at that.
Honestly, I would never buy these for use with a sub ONLY with an XO at 80. They do work, but there are other speakers that will work, and it seems like a waste of bass extension in the design.
Now, I wanted a speaker flexible for various placements so I went dome tweeter, but if I just wanted it out into the room with a sub, I would want the RAAL tweeter for wider dispersion. And given a crossover, I would go with the sierra 2EX V2, or maybe the Duo V2. If I stuck with Ascend. One a bit more, one a bit less money than the LX.
If you want 2 channel that hits 40 from a relatively small two way stand mount, then the LX is clearly among the top of any list for the money. If you want to cross with a sub... the options are wide open. The LX certainly does work well with a sub, but so do many other options that might save hundreds of dollars that can go to the sub or other gear.
Whatever one does, I doubt many people will be disappointed in the results.
