Thanks, I just noticed that a few minutes after I posted funnily enough!I have the piano black, if you look on the forum there is a sold sierra lx post and he has pictures of his piano black lx.
Ooh thanks, I didn't notice that customer page before.There are actual customer pics in the photo gallery: Ascend customer photo gallery
The drivers of the various models may be different, but the (bookshelf) cabinets are the same.
Also, these piano black, as already mentioned.
Hello,
Just wanted to ask are you using the LX in near field or entertainment center? I have been eyeing them to side grade for desk use.
Just wanted to add, the term "bright" I used usually refers to detail retrieval and analytical sounding speakers, not that they are very sharp, that's a whole other thing.They certainly do not sound "bright" or hurt my ears when playing louder
Hi guys, I had these speakers. Liked them more then Armins Revels. Feel free to ask any question. These speakers are very balanced.
audiosciencereview.com
I owned a trio of LX's for my LCR for a few months and sold them to upgrade to the ELX towers. I would be lying if I didn't say I missed the LX's. They were great in my room and I really didn't have any complaints. I'm most likely going to sell the ELX's and get the LX's again.... I picked up a pair of Sierra-LXs to compare with my M16s and the Sierras are fantastic.
Tweeter preference,I have the RAAL version of the ELX towers and after listening to them awhile I prefer the Titan dome of the LX,atleast for my listening habits. I would trade my towers for the Titan dome version but it would probably be easier to sell and just buy the LX again. I have dual PSA 15" subs so the lower bass extension and output of the towers isn't really needed in my small room.Wow, may I ask how the ELX's came up short? I was going to order a pair of them but I can't decide on what tweeter to select
Tweeter preference,I have the RAAL version of the ELX towers and after listening to them awhile I prefer the Titan dome of the LX,atleast for my listening habits. I would trade my for towers for the Titan dome version but it would probably be easier to sell and just buy the LX again. I have dual PSA 15" subs so the lower bass extension and output of the towers isn't really needed in my small room.
The bass is excellent,not as much deep extension as dual subs obviously, but I could see it being plenty enough for a lot of people,depending on listening habits and room size. I did a lot of listening without subs when I first got them and was quite surprised with how good they sounded without them.Jajdact, Thank you for the reply. This is why i found it confusing in selecting a tweeter. I read other posts where someone liked the titan more also. How did you find the bass quality of the elx without subwoofers?
You may be able to modify the crossover and buy some titan tweeters if Ascend Acoustics will give you the values to change and it's not a complete rework if you are up for it. I saw that the tweeter is 92.50 each on madisound.
How large is your room and how loudly do you plan to listen?Wow, may I ask how the ELX's came up short? I was going to order a pair of them but I can't decide on what tweeter to select
I have a small room,13'x14',and my speakers are usually 6' away,and I think that's part of the reason I preferred the LX bookshelves to the towers. I agree with everything you said about the dynamics of the ELX towers,it really is impressive,but they might be too much for my space.How large is your room and how loudly do you plan to listen?
I have both. The LXs are wonderful bookshelf speakers - they're very neutral/balanced and offer truly impressive bass output and power handling for their size.
To me, the ELX ribbon towers are on another level. Even above subwoofer frequencies, (upper bass) the ELXs are noticeably "punchier". They're smoother and less constrained sounding across the midrange. The directivity widening around the crossover region of the LXs (very typical of 2-ways) I think is a large reason why I prefer the ELX here. For treble reproduction, it's also an easy nod to the ELX to my ears. If you start really cranking up the volume (upper 80s to 90+dB from the LP), the scale of the ELX becomes progressively larger and more impressive than it does with the LX. I use both in essentially the same 20' x 11' room (one above the other, the floorplans are virtually identical). In a small/untreated space I can believe that the ELX might overwhelm the listener with reflected sound before the LXs would. You're then also much less likely to need to push either speaker to their limits (where the ELX has a headroom advantage). If your listening distance is rather short, as might be the case in a small room, the vertical window of the LX is larger and better suited to nearfield use.
