As good value for PC I/O as Echo Audiofire 12 ?
john61ct
Total interface noob here, please ELI5
I don't need to record or mix music in the creative sense, just looking to get multi-channel analog in and out of HTPC type hardware.
Primary use case is DIY convolving, loudness contour, bass management, room correction PEQ.
The Echo Audiofire 12 unit is based on Firewire which can apparently still works fine converted via PCIe card in a TB3 enclosure or certain docking stations
Apparently very high quality DAC/ADCs despite its age.
I REALLY like being able to go balanced/SE, both input and output individually switchable +4dBu/-10dBV input sensitivity / output level
Two Audiofire 12 units can daisy chain through just one port to the PC
The possible sticking point is Win11 drivers, apparently hardware designed for Win10 has broader compatibility.
I'm OK with this sort of futzing around, but do NOT want to get maybe forced into going over to Mac 8-O !
so I thought I'd ask for simpler modern alternatives - budget say $300 which is double the above.
Is TB required to get bandwidth / multiplexing for 12/24 channels? Or S/PDIF ?
Plain USB or maybe USB4 would be cheaper / more flexible on the host side, I'd prefer NUC style boxen
also the option to play with Linux, and/or rPi compatibility would be a plus.
Thanks in advance...
Up to 300 USD, not many options to be honest
The cheapest I would consider buying from the above list is the Tascam US-16x08 and it can do +24dBu
Thought I'd try here before starting a new thread
looking for a good value measurement XLR mic + pre-amp to use with REW*, into AudioFire 12 via TRS
Accurate transparency, good calibration a must, but I hope budget maybe $200-250
I understand that the AF12 word clock will be master, the only clock involved for both input and output, A Good Thing for accuracy, avoiding drift in correcting phase / time domain issues - REW can use a loopback input as "Acoustic Timing Reference"
please give ELI5 feedback if any of this is off base, noob here and I distrust Google results.
? Dayton Audio EMM-6 ?
for preamp, Rolls MP13 looks ok, but phantom power does not hit +48V
the 4-ch mixer Mackie 402-VLZ4 was reco, includes 2x Onyx (good?) preamps with gain control + LED level meters and proper +48V phantom power
plus 2x further line level inputs, I don't think I need the mixer function for this use case? But as bidirectional converter, the AudioFire 12 will still handle all the clocking (right?)
I'd prefer a smaller simple singleton dedicated pre-amp if both cheaper and better SQ, but not only-battery powered, USB power-in would be ideal
* + maybe Acourate but not yet settled ?
@Keith_W will this setup work well for the other DSP EQ programs too? Time-domain measurement looking like the toughest nut to crack? I realize the actual live processing ("convolving"?) can / should be a separate box, I don't think I want a PC tied up as part of my audio stack full time...
Q2 Has Acourate gotten easier to use since you wrote that review years ago?
So far list of learning resources, Q3 additions please
Mitchco's eBook
Scientists and Engineers Guide to DSP: http://www.dspguide.com
DSPGuru https://dspguru.com/dsp/books/favorites
Is Uli still on Yahoo Groups, or what are the better forums now?
Trying to answer some of my own questions here
pre-amp maybe a cheap Mackie mixer, see thread cited above
I understand that the AF12 word clock will be master, the only clock involved for both input and output, A Good Thing for accuracy, avoiding drift in correcting phase / time domain issues - REW can use a loopback input as "Acoustic Timing Reference"...
I've seen nothing contradicting this is the case.
Still stands if exists at say $150
Will add more learning resources @Keith_W has given, other Q's above as yet outstanding...
relevant
Update.
Separate preamp question solved, got a Mackie mixer lotsa ports, for peanuts.
Nice DP here, maybe even Win11
https://www.audiosciencereview.com/forum/index.php?threads/fan-less-silent-pc.41114/post-2611086
I may still prefer a TB3 conversion for simplifying an external enclosure, ability to run a smaller / quiet compute host (short on PCIe slots)
Dunno if all the ports are bidirectional? Seems to not be the case for some ADAT breakout boxes, all 8x analog ports must be input OR output as a block.
But these Audiofire12 units are so cheap,. Can 3 be daisychained via Firewire ?
I'm running an Audiofire 8 and an Audiofire 12 daisy-chained for 20 ins/outs total, and they work flawlessly on Windows 11. The machine is a Dell OptiPlex with an i7-9700, using a PCIe FireWire card.
One note that goes against most of the advice you'll find online: people generally recommend a Texas Instruments (TI) chipset controller - for me it was the opposite. My VIA chipset card works perfectly, and the TI one caused problems.
Latency figures:
  • Echo panel: 2.7 ms
  • Ableton: 5.33 ms in / 5.33 ms out
  • Total round-trip: 10.7 ms
I've just picked up a Dell XPS 8940 (i7-11700) and will be testing whether the same VIA card works there too. The 11700 is Rocket Lake, so no P/E core hybrid scheduling to worry about, which is why I went for it. I'll report back with the results once I have it running.
Excellent, thanks, and yes I've seen VIA recommended but not as much as TI. What card are you using?
The P/E scheduling issue is new to me, is that only on Intel mobos?
Can you link to discussion about that specifically affecting Firewire?
  1. Card: a PCIe FireWire card with a VIA chipset — I'll have a look at the exact model next time I'm in the studio, but I don't remember it offhand. Echo themselves recommended TI and most guides say the same, but for me it was the opposite: the VIA card was completely trouble-free while the TI one caused trouble (can't remember what was it exactly).
  2. On the newer generations: Intel had an instability issue with 12th/13th/14th gen desktop CPUs (voltage regulation), which was eventually fixed via microcode and BIOS updates. To be clear, the concern isn't really about FireWire specifically - it's about DPC latency and general stability, which affects any audio setup. Intel's own root cause write-up on it is here: https://community.intel.com/t/intel...-desktop-instability-root-cause-update/127016
Measuring the new box will take a while - I'm swamped right now and will get to it when I can. I may also test a newer generation later on.
Thanks again, useful stuff!
Besides RPi5,
I want cheap & quiet x86-compatible, so looking at older AMD Ryzen mobos, maybe AM4 era?
Kicking myself I didn't stock up on RAM and drives a few years ago...
Do you happen to know
> Can 3 Audiofire12 be daisychained via Firewire ?
Semi-related but I have a Mackie Onyx 400F (which I think was a collaboration with Echo) so if you need more of these things, LMK, great prices. :D
Yes I've seen them go for peanuts!
The main goal was listening DSP, compact (per port count) clean PC/RPi interface-only
no need for any mixing, recording etc music production stuff.
But for measurements, XLR mic preamps required, and this thread pointed me to Mackie Onyx, hence VLZ4 series
Ended up snagging a 1202VLZ4 for under $100 delivered, pretty big but can get put away once the measuring is done.
Then I picked up an E-MU 0404 USB 2.0 4x4 for $30 delivered!
So I guess I should sell the Mackie at some point LOL
Not sure but I guess you should consider the bandwidth load which goes to the Firewire of all these channels. Probably 3 are gonna work, dunno about more.
Audiofire 4 and 8 have 2 XLR mic preamps.
All set for preamps now LOL
At 48Hz max, not an issue.
But since BNC Word Clocked, could use a second PCIe card I guess.
To get to 36ch DACs if needed, in the event 2x Audiofire12 units is the daisychain limit off one port.
Now that I think, some cards have multiple ports on one card?
Asked Google about PCIe FireWire cards
TI cards (snd-firewire-lib)
StarTech 4-Port (PEX1394B3)
only one XIO2213B controller but decent throughput
Syba 3-Port Low Profile Card (SD-PEX30009)
XIO2213 chip
multiple independent TI chips even better, separate DMA streams / IRQ pools
StarTech 4-Port (2x FW800, 2x FW400)
There are older Pro / Multicore versions of Sonnet Allegro FireWire 800 e.g. FW800-PRO-E, not FW800-E only one chip
check out Unibrain FireBoard-800 Pro Dual (model# 1231)
Neousys Technology PCIe-FI32 / FI34
TI XIO2213B
VIA chipset (ohci-pci)
single VIA/VLI VT6315N
StarTech 2-Port (PEX1394A2V2)
multiple independent ohci1394 host controllers
EXSYS GmbH EX-16600
Kalea-Informatique Multi-Controller PCIE-VIA-3B
3x separate busses, no daisy chain!
Syba 4-Port SD-PEX30016
verify chips
cat /proc/interrupts | grep -i ohci
lspci -nn | grep -i 1394
assign the FireWire card's IRQ line to a dedicated CPU core using irqbalance or by manually writing to /proc/irq/IRQN/smp_affinity
ALSA aggregation via .asoundrc
I’m not an expert, so my understanding of the specifications may be limited. My both Audiofire interfaces (12 and 8) have two FireWire ports and two BNC ports (one input and one output each), so I’m running one FireWire connection from the PCIe card to the AF12, and another from the AF12 to the AF8.
The BNC connection runs from the AF12’s clock output, selected as the master clock, to the AF8’s clock input. The AF8’s clock output is therefore free, so I believe it should be able to re-transmit the clock to another interface if needed.
I hope this makes sense.
Yes, BNC Word Clock is its own "network" can support LOTS of nodes, but best in a star topology.
I was asking about daisychaining the units for the audio signal via FireWire.
Officially Echo say only two per FW controller.
So above I discuss FW host cards with more ports off multiple controllers.
Nothing to do with BNC WC.
But thanks, the VIA comment is gold
