Oh yes I realize the wishlist makes for a challenge! This thread is very specific, narrow on purpose
The "cheap" part in least priority just trying to collect my options in the PCIe subset.
to further clarify, 8x analog channels, that AIO card has so many digital options but not what I'm after.
And yes I am deep into the wide world of pro interfaces, ADAT expansion converters etc.
I've not used the 830668, so not sure to what you are referring. In my Purveyor build, I used that PR, with the 5.25" SLS woofer, not the 10".
www.audiosciencereview.com
So obviously well aware of the RME product lines as a result and some of the legacy ADC/DAC options are reasonably priced per port secondhand
In fact I've picked up RME Digiface / Multiface expansion breakout boxen super cheap
but these usually come with PCI or Cardbus (requires futzing around)
My goal is not recording or mixing / producing music, but a high count of multichannel DSP and crossovers for recreational reproduction, cheap. If members have other similar gear sitting in closets, or alternative suggestions feel free to speak up. In this case I like the RME OG Hammerfall...
while the modern PCIe options are usually well over $40 per port just for the card
Same with USB interfacii, I almost snagged an RME Digiface USB (32x each I/O channels at standard resolution) for $310 shipped, but not planning on paying $400+ given the cost of decent converters needed on top.
I am looking for an interface "hub" based on multiple ADAT, clean and transparent. I'm not recording / mixing, just for recreational home DSP - crossovers timing delays / phase alignment tuning Happy to buy secondhand to save money, vintage discontinued no problem. 24-bit, 44.1 / 48kHz is...
Legacy Firewire based stuff is very well priced, but futzing around and limited lifespan.
Total interface noob here, please ELI5 I don't need to record or mix music in the creative sense, just looking to get multi-channel analog in and out of HTPC type hardware. Primary use case is DIY convolving, loudness contour, bass management, room correction PEQ. The Echo Audiofire 12 unit...
Currently looking at legacy Yamaha processors for keeping PCs out of the signal chain
the Mini-YGDAI card platform gives incredible flexibility and value for money, especially given those processor base frames that offer slots for 4x cards, some 16x channels each.
$10-20 per channel even for analog and AES3, much less for ADAT.
Looking for, with the MY8-TD ADAT version 8-port Mini-YGDAI Expansion Card what I've gathered not an interface, just "breakout box" converter, in my case I'll need an interface with ADAT inputs, e.g. RME Digiface USB zero digital outputs on its own Usually the included Mini-YGDAI Expansion...
Thanks to @Frunse for turning me on to the various AES- related digital transport media formats, especially AES3 aka AES/EBU. My system after per-driver amping, MBM reinforcement + several trueSubs, in general active crossovers and signal upmixing may end up with 20+ output channels. I am...
please discuss each of these "off topics" in a relevant thread
This one for
> PCIe with 8 channels, not discontinued, either well accepted Linux software or UAC2, plus updated ASIO drivers for modern windoze
