I hate to show my bias here but before even testing the LP-10, I expected subpar performance. But even I was not ready for such poor performance. Yes, $79 is not much to spend on a streamer but what is there needs to impart some level of competence in design. None exists no matter where I looked.
I can't recommend the Arylic LP10. I hope the company cleans up the design and offers a new version that has at least reasonable performance.
Crossing fingers that Toslink output would be bit exact, I tested that digital output:
The jagged sine wave shows some serious problem there as well as copious amount of jitter showing in our FFT spectrum. Truly broken.
I moved on to testing the analog input with the same Toslink output:
AFAIK, the answer is currently 'No' as the WiiM Mini streamer does not support Roon.Are there any streamers under $100 that you DO recommend?
They are not very user friendly but Raspberry Pi based streamers with some kind of HAT will do the job there.Are there any streamers under $100 that you DO recommend?
The stairstep response on Toslink definitely indicates lots of ultrasonic content.This pic doesn't tell the whole story. The FFT does not show 30 dB SINAD, but something much better. As the AP reveals it received 96 kHz via SPDIF. So the reason for the bad SINAD must be above 20 kHz, not visible here. But it also raises the question if that is the reason for the badly working SPDIF output as the next pic shows that TOSLINK basically could work ok:
That's correct. I always try to wire up the channels that way.@amirm,
When your AP measurements reference channels by #s [i.e., 'Ch1' and 'Ch2'] is Ch1=Left and Ch2=Right channel?
Wow, clears the 3% THD+Noise ratio. That should be audible to most people. Impressive! (In a not good way.)
Sorry, I thought it was toslink analog input. If it is digital output then I changed my vote.Wow, totally shocking. The jitter in that output is by far the worst I've ever seen...
One good reason to buy this thing - to finally hear what jitter sounds like.
When you consider that the WiiM Mini costs barely more than this and is totally competent, this result makes even less sense.
The worst graph above is Amir's test of the toslink output from streaming input! Which should be bit-exact or at least extremely clean, as you note, but somehow manages distortion that I think would be easily audible.
Looking through mfi.apple.com it looks like the Cambridge Audio MXN10 might tick the boxes but of course no one has looked at it to check the digital output is not broken.I was going to invest in WiiM but their current designs do not do AirPlay, probably so some violation of the MFI program that we aren’t being told about.
Aurylic looked plausible but the utterly broken digital out kills it, I don’t care about the analogue out as I’d never use it.
There doesn’t seem to be a product family which:
- Does Spotify lossless
- Does Airplay
- Does DLNA/UPNP
- Has a bit perfect digital out
Available.
There are other reports of this device not matching the input sample rate to the output sample rate, for example outputting 88.2 when playing back 44.1 content. However as you say if they have not got this right, or done the upsampling correctly who knows what else is lurking in the audio pipeline.This pic doesn't tell the whole story. The FFT does not show 30 dB SINAD, but something much better. As the AP reveals it received 96 kHz via SPDIF. So the reason for the bad SINAD must be above 20 kHz, not visible here. But it also raises the question if that is the reason for the badly working SPDIF output as the next pic shows that TOSLINK basically could work ok:
Here we see a clean digital signal signal, now at 44.1 kHz (with a big deviation of 4.3 Hz though, internal clock seems to suck too), only tainted by the (most probably) very cheap AD conversion. So maybe the 'stairstep' sine from before was due to sample rate mismatch?
Of course Amir would say 'no need to waste more time with it'. And I would agree with that.
Measurements seem to indicate that this device works fine with an external DAC. Well, to me, the Arylic mini analog out also sounds great...... At normal volume, THD is like 0.1%, so to me it seems plausible that this is compatible with "sounding great". Great speakers exhibit higher levels.There are other reports of this device not matching the input sample rate to the output sample rate, for example outputting 88.2 when playing back 44.1 content. However as you say if they have not got this right, or done the upsampling correctly who knows what else is lurking in the audio pipeline.
