Arylic LP10 Budget Streamer Review
Rate this streamer/DAC/Preamp:
    Votes: 194 96.0%
    Votes: 3 1.5%
    Votes: 2 1.0%
    Votes: 3 1.5%
This is a review and measurements of the Arylic LP-10 streamer. It was kindly drop shipped to me by a member and is on sale for US $80.
The streamer is ultra compact and light. Front panel font is quite small but is still legible at close distance (looks better than the above photo).
A remote control is provided as well as a USB power supply although you can also power it from your computer:
Arylic LP10 Streamer DAC Stereo Chromecast remote control preamp back panel spdif toslink review.jpg
I was pleasantly surprised to see inclusion of ethernet port. Low cost streamers tend to be Wifi (and Bluetooth) only. This removes the need to figure out how to configure the thing.
I tried to use the USB-c plug as data interface, treating it as a DAC but would not work. It can only be powered that way. I then tried to use the Toslink as an input but that didn't work either as it is output only.
The main source of analog output is the 3.5mm. I was yet again pleasantly surprised to see analog input in the form of another 3.5mm input -- something many streamers and certainly DACs lack.
The USB-A port is for a thumb drive but it says it has a limit of 1024 songs. Seems pretty useless to me.
Using the web interface, I checked for firmware update and it said it is current.
Arylica LP10 Streamer Measurements
I connected the unit using Ethernet and then used my Roon player to stream to it. Was pleasantly surprised to see it advertise Roon protocol. Alas, as soon as you attempt to use that, Roon warns that it is not certified so wont' let you do anything with it. Using the "Go" App, I turned on Chromecast and performed my streaming test using that. After setting the volume to max, this is what I got:
Good grief... That is a ton of distortion! As a DAC, it would rank at the bottom of some 400 to 500 DACs tested! Figuring it may be past its limit, I lowered the volume to 82:
That certainly helps but now you have anemic output and still a lot of distortion.
Crossing fingers that Toslink output would be bit exact, I tested that digital output:
Arylic LP10 Streamer DAC Stereo Chromecast Volume Max Toslink Out Measurement.png
The jagged sine wave shows some serious problem there as well as copious amount of jitter showing in our FFT spectrum. Truly broken.
I moved on to testing the analog input with the same Toslink output:
Arylic LP10 Streamer DAC Stereo Chromecast Volume Max preamp analog in Toslink Out Measurement.png
Compared to streaming input, performance is better but still nothing to write home about.
Testing analog output reduces performance a ton yet again:
Arylic LP10 Streamer DAC Stereo Chromecast Volume Max preamp analog in Analog Out Measurement.png
I don't know about you but I am done testing the LP10.
I hate to show my bias here but before even testing the LP-10, I expected subpar performance. But even I was not ready for such poor performance. Yes, $79 is not much to spend on a streamer but what is there needs to impart some level of competence in design. None exists no matter where I looked.
I can't recommend the Arylic LP10. I hope the company cleans up the design and offers a new version that has at least reasonable performance.
Ouch... Probably the worst measuring streamer so far.
Amazon makes no great claims.
Arylic LP10 Wireless Music Streamer, Supports AirPlay 2, Apple Home and Spotify & Tidal Connect Multiple Streaming Options,5G WiFi and Bluetooth Preamplifier with App, Remote Control.​
I guess it comfortably meets a need for casual / non audiophile listening.
Presumably it'll work better using it as a digital streamer, outputting to an external DAC.
You could also use the analogue output as a sub out where the bad measurements are less of a concern.
Still not a great option tho, I guess.
Presumably it'll work better using it as a digital streamer only, outputting to an external DAC...
See the review. I tested that and it is horrible.
Doh, sorry. Missed that. Just skimmed it and yet to have my first coffee.
Yes, they really should get at least this right. Very poor indeed.
Maybe they want to be awarded a Guinness record :p
But seriously: I wonder if a firmware update might improve it - looking at the "stairsteps"...
Thanks for the review, and the warning! This is needlessly nasty.
Best use case is as a Meh ADC, everything else is awful.
Oof.
I’ve got one of these waiting for me under the Christmas tree. I’ll give it some time for listening impressions while I work from home all next week. Hardly plugging it into a high end system. Audioengine D1 DAC, Yamaha RS-201 receiver, and Sony SS-CS5 speakers.
How is this even possible?
Company should get an affordable Cosmos ADC and do some basic measurements to ensure proper function before selling a product to the market...
... Impossible to play on an acoustic guitar.
Due to them being analogue.
(Thank goodness.)
Everything need to be digitally output, such as Wiim Mini for that kind of price.
