- Thread Starter
- #21
Sure, but then again the software I use might have different algorithms, making comparisons less fair.I'm thinking that if you up-sample the low resolution file you should get an apples-to-apples comparison in the FFT/spectrum.
Absolutely, but some people still claim that one is 'objectively better' than the other, despite that they just prefer a version that is 6 dB hotter, without listening level matched.When there is an obvious difference, the first thing I suspect is different mastering. Or it could be a different mix or a completely different recording. The high-resolution version might be better, or if it's newer it might be a victim of The Loudness War and sound worse! (Or you might prefer the more dynamically compressed loudness war version.)
Just choose the version that sounds best to you!
Yeah, I bundled noise and distortion together. I also used the expanded meaning of sound, even ultrasonic. My aim was to find out whether hi-res files contained actual sonic information like true overtones or bat sound or cricket sounds (or waves of variations in air compression like when a tree falls in the forest and so on). The audibility is another discussion, which is largely over and doneNoise is the "rumor". Maybe distortion too. I'm not sure, but if it's ultrasonic, by definition it's NOT "sound".![]()
But it appears that any additional information contained in hi-res files at best is just a waste of data like I previously stated.
