This is a teardown of the ART (Applied Research and Technology) SLA-2 studio power amplifier. It is a 2-channel amplifier that is marketed as having 10 Hz to 40 kHz response all within 1 dB. It fits in a 1U rack space.
The unit pictured here is 10 years old.
Input:
There is a switch for bridge mode.
Texas Instruments TL084CN
Bridge rectifiers:
Each side of the amplifier has power devices attached to a heat sink.
KBU8J (bolt and washer removed)
Power transistors:
There are power devices under each heatsink. A flexible inspection scope is helpful here.
Toshiba 2SC5200
Capacitors:
Each side has two bulk capacitors.
4,700 μF, 80 V, 105° C
Harnesses:
There are three long signal harnesses.
A: 2-conductor
B: 2-conductor
C: 3-conductor
This unit's harness B is missing a gray jacket because it was replaced during a repair.
ART/Yorkville say that harness C was added as a production change to lower the noise floor.
That's all. If there are any questions, I will try to answer.
Input:
Bridge rectifiers:
Power transistors:
Toshiba 2SC5200
Capacitors:
Harnesses:
A: 2-conductor
B: 2-conductor
C: 3-conductor
