Would be good to see if optical and coax outputs are comparable. In some other streamers they have been materially different.Yes. That is the only output I tested.
This application is compatible with Qobuz
That’s what she said.Compared to a tv media box it's still quite big View attachment 445554
Siri or Alexa?That’s what she said.
Because for example; if I were to purchase it I would feed it into the DAC that runs my speaker system which also is fed from my TV and HTPC. So I would output from this using Coaxial into the DAC so I could switch to the streamer.What would be the reason for that? It already has good enough DAC.
Needs at least 200 hours of burn in to sound its best.... 300 for that last final bit of resolution, soundstage depth/width, veils lifted, blacker blacks etcI have run this product in my system for about an hour now. There is definitely a hole, in my soundstage.
Did they show the measurements in the tet-a-tet chat? I don't see any website for this company.When the company reached out to me to offer a sample to test, I almost said no until I saw that they had Audio Precision measurements showing excellent response.
I looked. All three of them from "Vine Customer Review of Free Product" are useless. Basically, as is always the case with companies of this kind, they focus on the hardware but lack software, user manuals, and customer support. Then, the average consumer (unless they hold a degree in computer science) is frustrated by not understanding how to use the basic functions of the device, unhappy with apps that require installation and registration with personal data, etc.Did you look at them? There are only 3 reviews. One is 4 star. One is 2 star and one is one star. The two star one makes a bunch of assertions about forced resampling, etc. which would require a lot of knowledge and instrumentation. Doubt he has that. He then says there is a headphone amp in there and you connect your headphone using USB-C? What the heck? The two star one says he couldn't connect to anything. Maybe that was the case in February 15th when he post the review. None of the issues they mention were there in my testing, albeit, in different scenarios.
I don't know what you are saying. There are instructions on the website. There is not much to it other than configuring WiFi if you need that. You plug it in, and it shows up as a playback device with specific applications. The simplicity of this product specifically deals with the issues you talk about. There is no requirement or need for any registration as there is with app centric streamers such as sonos, etc.Basically, as is always the case with companies of this kind, they focus on the hardware but lack software, user manuals, and customer support. Then, the average consumer (unless they hold a degree in computer science) is frustrated by not understanding how to use the basic functions of the device, unhappy with apps that require installation and registration with personal data, etc.
Very interesting thanks.
Seems they also have a simpler model ne-3 without spdif output but still usb out and a different dac at a lower price.
This is a review and detailed measurements of the ARSY Ne-2 streamer. It was sent to me by the company and currently is on sale for US $159.
The case is no bigger than the CD jewel boxes. The design is minimalistic with just USB-C input for power and everything else, output:
Simplicity extends to NOT having or needing an app to control it. Plug it in, and it should appear as a destination in various streaming platforms. In my case, it supports Roon player so that is how I tested it. Without the app, you need to wire it using Ethernet first, find its IP address and using its simple web interface to program WiFi network/password. And upgrade it (which I did). For power, I just used a random USB-C charger I had around.
If you are not familiar with amplifier measurements, please watch my tutorial on it:
[And subscribe to the channel]
ARSY Ne-2 Streamer Measurements
Since I am limited to test files I can play using Roon, I don't have full suite of measurements for you. But enough to get a very good picture of Ne-2's performance starting with our dashboard (only analog out is tested throughout):
Nice! Distortion is well below threshold of hearing so we are noise limited.
The Crystal Semiconductor DAC performs some kind of dynamic range scaling to produce better results in our DNR than expected:
Jitter spectrum is ultra clean, showing well designed device:
Multitone test shows a bit of increase in distortion in bass which we often see. Otherwise it is excellent:
We have the usual filter design:
THD+N vs spectrum looks very good:
When the company reached out to me to offer a sample to test, I almost said no until I saw that they had Audio Precision measurements showing excellent response. So I accepted a sample and I am glad I did. This is a no frills streamer/network to digital audio streamer that performs excellently. I personally can't stand having to use an app to control a streamer. I want to plug the thing in and just see it at the end of the wire/network. Ne-2 streamer does that and does it extremely well.
I am happy to recommend ARSY Ne-2 streamer.
I get that, but if you use more than one streaming service then you have multiple UIs. The advantage of 'Pull' is you only have one UI to contend with.
Obviously, it has to be a decent one. I'm happy with the WiiM's ... it's better than the native Amazon one IMO.
It’s missing Chromecast and AlexaCast, as well as voice control and a BT remote control, all included with most WiiM devices. The WiiM will be easier to configure for WiFi, and supports MANY more services. So, unless you’re set on Roon, the WiiMs have many advantages for most folks.is there any advantage of this over the Wiim Pro or Wiim Pro +? That is a tried streamer with constant updates and measurements for the same (if not cheaper) price.
Are you suggesting many people don't have a) an ethernet cable and b) the wherewithal to plug it into a spare RJ45 socket on their switch/router? I've certainly never come across a router without *any* RJ45 sockets.That's fine in some situations but it means it can't be used in a lot of homes.
