Hello everyone,
I would like your help regarding two potential solutions for streaming:
-Argon Solo
-Wiim Mini + Topping E50
I do not own any other DAC, so in the first solution the job will be done by Argon's. Also, I do not use, nor I plan to use, Roon. I listen mostly from Tidal. Argon solo does not have Tidal Connect so you have to stream it through Chromecast at maximum 24/96.
Do you think that there going to be any audible difference between the two options for Tidal use?
Thank you!
-Argon Solo
Thank you!
