Arendal 1961 Towers vs Revel Concerta2 F36
Grierts
Looking for some comparisons between these two speakers ?
Anyone heard them both?
I hear the arendals have a more narrow dispersion pattern?
How does this affect real work usage
I can get the arendals for $1200/pair
The f36 open box $1100/pair
Two svs subs paired with them 1000pro
Correct:
SPL Horizontal Contour Normalized (2).jpg SPL Horizontal Contour Normalized (1).jpg
SPL Vertical Contour Normalized (2).jpg SPL Vertical Contour Normalized (1).jpg
(F35 and F36 have the same dispersion)
The F36 will have a wider sweet spot, so you can stand or sit further off-axis before you notice a change in timbre.
The F36 also has a slightly brighter tuning and better bass extension:
Correct:
View attachment 367752 View attachment 367753
View attachment 367754 View attachment 367755
Have the Concerta2 F36 been reviewed here, by Erin or on Audioholics? Or somewhere where reviews are based on measurements ?
If I may ask, where did you get these measurements from ?
I am considering getting a pair... how do they compare to the Polk R700?
No measurement-based review exists of the F36 AFAIK.
The closest I could find is this:
The measurements come directly from Revel, and can be viewed and compared to other speakers here:
