I have owned this center for a few years, two in fact in two different setups. The Room is the issue with MTM's. my main room is narrow, no seat is more than 7.5 degrees off access. I would have to extend further than my 3 seat couch to hit audible lobbing territory. That would put person 4 on the floor, a foot from a side wall, directly in line of of the whole right or left side speakers (7.1.4) which is going to throw the whole image, bed layer and atmos dominating the left or right side speakers. Bass is very reinforced close to my walls, not even at all, add in the fact the whole image is blown as you are so far off center that on side or the other is gong to be louder than the other depending on what side floor you want to sit on next to the couch.
In my case, lobbing or combing is the least of my worries due to the above and would not even be the main factor for blown sound.
Wide rooms, I get the worries,narrow rooms where seats are not very far off center is not a issue.
I have been through about 20 centers in my life, mostly 3 ways, at least 8 of them were more than double/triple the price of this unit. The 1723 THX center blows all but one away but one (a 3 way), and that one sounded quite different, some may have a preference between the two, for me either was is great but since it's a full Arendal setup (other than sub) the other speaker does not mix well (I still have it)
The point is MTM's are a issue, BUT only once you hit the off access point where things become audible, in my room 7.5 degrees either way, (15 degree spread over the seats is not audible. Check the charts, see at what degree things start falling apart and check and see if any of the seats you care about are in the zone.
I still maintain that in many rooms the MTM issue when outside the off access window s going to sound like crap for many of our rooms to such a extent that combing is the least of the issues. My sub alone with the way bass piles up near walls I expect would make any combing inaudible, not in a beneficial way, the bass will be so thick and uneven it's going to sound like total crap masking any other lesser audible issues. Combing over that level of muddy bass is not going to be heard, the seat would be way worse than that. It's a bad seat period that should never be used due to endless issues far more serious than a MTM outside the zone issue.
Once again, disclaimer, this thought only concerns narrow rooms and the dispersion pattern.
FOR me the question is not is a MTM a bad idea, the question is "Is it a bad idea for your room?"
PS: First post, long time lurker, that odd fun power cord war last month and the conclusions told me to register as I was in the right place.
