Arendal 1610 SLIM 8 Speaker Review
Rate this speaker:
    Votes: 5 2.7%
    Votes: 28 15.2%
    Votes: 115 62.5%
    Votes: 36 19.6%
All this nonsense "My original question remains unanswered: Where are the commercially available, comparably priced, low-profile on-wall loudspeakers that demonstrably outperform the Arendal as a complete product?" someone asked you this, can you give examples of said speakers or not?
if not maybe move this onto a sperate thread where you can all go nuts on.
Bulking this one out with bullshit from not just you but others to. I dont care for scrolling through 5 pages of this just to find the odd helpful comment.
Is it not obvious at this point that I simply do not care to entertain this request? It's not even relevant to the points I was trying to make. Sigh...
No one ever answered any of my questions so it's fine.
I say the speaker was not hard to design, you say it was. What sort of back ground do you feel you have that gives you confidence in your opinion? All I asked.
I don't work in the medical field, so I don't make comments about how difficult the production of a medical device is/was, or whether a procedure is difficult to execute. If I wanted to know some info on that, I would ask someone with experience in the field. I would not just assume.
Something something marco pierre white "I am being judged by people who know less than me".
I apparently have a fan club now according to my PM's.
You're still avoiding the question. Rather than substantiate your claim, you've retreated into your personal experience and now want to debate my qualifications instead of your own assertions.
Your experience isn't in dispute, but it doesn't make your opinions beyond scrutiny, nor does it relieve you of the burden of supporting them. Frankly, you seem more interested in establishing your authority than defending your argument.
So, once again, which commercially available, comparably priced, low-profile on-wall speakers demonstrably outperform the Arendal?
It's a straightforward question. You've spent considerably more effort avoiding it than answering it.
Entitled.
Is the graph "Relative (THD) Distortion Comparison" new? I am used to looking at the following graphs in dB followed by %.
I think the graph needs less smoothing and a key to connect graph colors with dB SPL.
It is an interesting way to understand how "as I turn it up", or dynamics affect frequency peaks of distortion. Is that detectable by the human ear?
New-ish.
First appeared four months ago:
I am working on better analysis of the distortion. In that regard, I computed the difference between 86 and 96 dBSPL. In an ideal world, as SPL would rise, distortion would rise the same amount, keeping the above ratio the same. Naturally we are already into non-linearity which means distortion is rising more than the SPL:
Then refined into its current form shortly after:
Here is a comparison of the total THD at the two levels:
PreSonus Eris E3.5 Near Field Studio Monitors relative THD Distortion comparison Measurements.png
From bad to worse.
My 2 cents: there is a lot of focus on FR and horizontal dispersion in this thread, but in the end every design has
Its stronger and weaker points. There is no perfect speaker out there. Arendal uses a klipple measurement device to design its speakers, so if they wanted to have these 2 graphs ruler flat they could have done that easily (the're also both not ruler flat for the 1528 line).
I think they are trade offs for the fact that they placed the tweeter so close to the midrange (which gives a almost concentric design and has its own benefits) in combination with the other design goals: lots of undistorted headroom, lots of bass, curved baffle etc.. Not all benefits of these design choices are measurable or at least have to be judged relative to eachother IMHO
Quite apart from their technical construction, it must be said that these crossovers from Arendal are simply beautiful to look at.
Keeping those sharp edges is a bit silly as it hurts imaging due to diffraction.
One problem is that you share things like this as they are facts. It is not difficult to find speakers with 90 degree cabinet edges that have great imaging, so your statement is not universally true.
We also know nothing about the imaging of the Arendal 1610 slim and to what extent its imaging is suffering from cabinet edges, as imaging is not something we can readily tell from the measurements.
What is the sonic impact of putting it against a wall, which this speaker is designed for but is not where speakers are commonly put?
Thanks, Mike
I like the on-axis response, meaning it correlates with what I might seek for a neutral if a bit lean sound. This is because the dip around 150-200Hz can be helpful in keeping the bass from sounding to rich or bloated in my opinion. Distortion above 80 Hz looks good and the speaker is not all that expensive and can probably be used at decent SPL without sounding strained. I hope to give a pair a listen someday!
Arendal has an Ambassador Program where some of their customers showcase their own systems and are willing to host visitors for listening sessions and discussions (with the owner's consent, of course). You can check Arendal's official website to see if there are any ambassadors near your area.
Thanks, Mike
Arendal's founder said these slims make excellent LCR speakers with a subwoofer ofcourse. So they are quite versatile in their placement options.
Thanks, Mike
You get strong comb filtering at a higher frequency vs when the speakers are further away from the wall. There are other effects but that is the 1st main difference.
You will want to research SBIR (Speaker Boundary Interference Response)
The second is that the Baffle step compensation should be omitted or nearly omitted from the speakers crossover design. Speakers further from the wall lose more bass and lower midrange energy as the sound wraps around the speaker, sending much of the energy rearward behind the speaker and then you get cancelations as it all bounces back forward & all around.
(These cancelations happen with on wall speakers in higher frequencies, the bass and lower midrange is generally reinforced and not canceled and not wrapping behind the speaker)
That is part of why Arendal likely tuned the 300hrz dip but these still seem to have some small amount of baffle step compensation so they may sound slightly thicker and a wee bit chesty on a wall. Conversely these should sound a bit thinner than neutral out on stands well away from the wall.
The speakers may not sound as spacious on a wall but that will be subjective and definitely recording/content dependent.
On wall and in wall speakers seem to many people to have less imaging fun, less depth and sense of spaciousness. Where the opposite design, a dipole seems to many to have unreal levels of imaging and spaciousness. IDK so much will be subjective biases.
Perhaps great in isolation, but once you start comparing speakers without diffraction issues, not just in the tweeter, the differences are often obvious at least to trained ears. Grimm LS1 would be a revelation to most people who have only ever heard your typical 8" baffle width speaker.
Everything I say is backed up by data and correlated with listening tests ¯\_(ツ)_/¯ I know what I've measured and I know what I've heard, I'm going to keep pushing this idea that diffraction is bad until well, I suppose the physics of sound waves happens to change.
You state many things facts as well, however it can often be in disagreement with data so I don't feel your comment is warranted at all.
...Everything I say is backed up by data and correlated with listening tests...
Can you provide some links/citations? I have never been able to find a good blind listening test that examined the audibility of diffraction from speaker edges, much less its impact on imaging. That would be pretty useful to see. (Note: I have seen lots of studies of the measured effects of 1/4-inch, 1/2-inch, 3/4-inch, etc. roundovers and chamfers, but never actual tests of the audibility.)
I feel like arendal knows they dont need to have perfect response cause a lot of their speakers are going to be sold to home theater guys who are going to DSP to some HT target anyways.
I use them as front highs and surround side and couldn't be more satisfied, they look good too.
