Arendal 1528 high end speakers
It's been said many times that adding a subwoofer to a 2.0 system improves the midrange. So, maybe something similar is happening here? You have the port unplugged to extend the low end, so the midrange may sound different now because you've changed the low-end-to-midrange ratio, so to speak. Try moving the speakers away from the wall to cut that extended bass spl a bit, so that you may get the original balance you had when sealed, but with lower extension.
I never used a sub for this setup. And can’t find room for one either sadly, given how big those 1528 monitors is. But you need to make sure you get at least a pair 12 inch or larger or 1528 monitors will have better bass on their own.
The thing i noticed with those speakers is that they are very revealing. I do find some old rock recordings unlistenable at higher levels.
Then you either plug the port to reduce the low-end SPL a bit and adjust, or unplug it and move the speaker further from the wall.
I find it interesting that some recordings you knew well now sound unlistenable because of these speakers' revealing nature. A well-known trick by loudspeaker designers was to peak the high end (increase the high-frequency response) of their tweeter designs to make their speakers 'revealing'. Good for marketing!
1. Are you sure the frequency response in your room does not peak at high frequencies?
2. The monitors have 2 switches in the back, where you can tame the high and low end by 2dB. Have you tried it? :)
Yes. And frankly, some recordings are just made with excessive treble. Not everyone has speakers that dig deep and go high...
Yes i have the jumpers on low for both the tweeter and midrange.
When i am saying revealing that is not that is bright or dark, the Arendal is not really that bright.
It just means they reveal more into the recordings. With lower end speaker you can get away with poor recordings more, some recordings on Arendal will just sound better.
But i dont think it sounds bad even on things like saxon, but it can become a little harsh on higher volumes with that artist. But playing something like acdc works a lot better. Things like Taylor Swift sound incrediable clean.
With my first set of speakers b&w 683 s2 i could play basicly everything they was so forgiving but at the same time everything sounded the same.
But i would still say the Arendals handles most recordings just fine even through some are better than others.
I know an Arendal 1528 who is selling their 1528 slims because he was more impressed by Theory SB25/75 sound quality. Surprised as I thought the Arendal with its superb bass performance would do better.
Seems like the issue i had with lack of midrange clarity was because of the jumpers that adjust tweeter and midrange removed them and put them back and now the clarity is back,
I have tried so many things to get it dialed in,
When Arendal 1528 monitor 8 is dialed they sound absoutly mindblowing,
They are so good that i might consider them as endgame i dont miss anything.
Outstanding speakers even through they can be hard at times to get right.
I have stopped thinking about speakers and just enjoy the music, which was never the case before.
Slims have no bass, by design (-3dB at 100Hz or so). They are made for surround sound duties. If you want to use them as mains, then pair them with a subwoofer.
Seems like a mechanical connection issue? Maybe a warranty claim may be in order.
Could be that the jumpers was loose. If i notice that again, i will look more into it.
But in nowhere i would think Arendal 1528 monitor 8 with Hegel h390 would run out of juice with listening at around 7-8 feet away, they designed with much futher distances.
Even at high volumes. My ears should be more the worry than the equipment.
Guess I'm an "insider". Anyway, enjoy! (Walnut, Dark Walnut, and Smoked Eucalyptus.)
I reserched futher with the jumpers on my Arendal 1528 monitor 8 and it dosent look to be my issue at all,
My gaming pc is causing noise when its on and i have no Idea how to fix it. I have ps5 as well but there is no proplem there.
Go optical.
Or a High Speed USB isolator usually does the trick if you want USB connection.
Only make sure is up to the task, some are power limited, if you use an audio interface for example.
It's iritating that at this time and age where strong GPUs are noise generators (amongst other sources of noise in a PC) is not a standard component to every DAC.
