I can't remember having mentioned that on several occasions, and if so I at least did not mean that as a negative comment on Arendal. I try pretty hard to not to comment negatively about competitors or other manufacturers in general, or at least do so in the most objective fashion possible.
I don't think the weight has so much to do with the specs of the speaker necessarily. I would assume most of the weight of the 1528 series comes from the way the cabinets are designed. A combination of high density panels and very thick panels. And the speakers in general being relatively large. I use relatively high density panels on our speakers too, so nothing wrong with that.
The 1528 Tower is 135.0 x 29.0 x 54.8 cm and weighs 79kg.
The Saranna is 110.0x28.4x34.0 cm and weighs 44kg.
So the Saranna is quite a bit lighter, but also significantly smaller, and have one less 8" driver. Someone with a calculator can probably check the difference in kg per volume or something.
What I do and would do differently is probably mainly to not have so thick panels, and pursue sufficient rigidity through bracing instead.
