Robin L
A specific, and very expensive, neurosis. If it isn't already listed in the DSM - 5, it should be.I think audiophilia more as an affliction/disease....
They regularly perform valid performance tests on speakers and all other audio components by listening to them. However even these tests aren’t 100% valid, especially on individual components. They don’t take into account the synergy when a component is inserted into a different system and environment. Had a wry smile when Devaliet stared matching on line their Amps to speakers. The same people who applauded this would likely sneer at the use graphic equalisers. Devaliet would have been better to have gone down the Dirac route for system matching. When it comes to testing the results are only as good as the person interpreting them. Quite often they are used to justify a long held opinion. Worked in the electronics industry for many years and have witnessed it many times.As a subjectivist measurements are just a snap shot under strictly controlled condition.- I agree, this is pretty good definition of a measurement
Sort of like looking at cars in brochures, until you get in and drive them you just don’t know which one suits best.- No, this is not what a measurement is like if you understand them. Not at all
There’s a speaker thread at the moment how does a cabinet resonate over the full frequency and power range with different types of music? No test procedures can cover this, the only valid test is what you hear. I'm no expert but I am pretty sure someone competent could (and probably has) devise a test that would measure pretty much how a speaker would perform in these circumstances.
Never understood the concept of synergy as applied to hifi. Seems like trying to correct one fault with another. Much better to avoid the fault in the first place by buying correctly through measurements.They regularly perform valid performance tests on speakers and all other audio components by listening to them. However even these tests aren’t 100% valid, especially on individual components. They don’t take into account the synergy when a component is inserted into a different system and environment. Had a wry smile when Devaliet stared matching on line their Amps to speakers. The same people who applauded this would likely sneer at the use graphic equalisers. Devaliet would have been better to have gone down the Dirac route for system matching. When it comes to testing the results are only as good as the person interpreting them. Quite often they are used to justify a long held opinion. Worked in the electronics industry for many years and have witnessed it many times.
I think that this is an over simplistic perspective. Surely you would agree that not all components, particularly speakers sound and measure (FR particularly) the same. Sometimes, particularly if you don't EQ, matching components makes sense... Or no?Never understood the concept of synergy as applied to hifi. Seems like trying to correct one fault with another. Much better to avoid the fault in the first place by buying correctly through measurements.
S
No. All loudspeakers have frequency response errors, which can be corrected by equalisers. That's what they're for, and should be part of every loudspeaker system that doesn't use DSP equalised active loudspeakers. Trying to correct a , say, bright speaker with a 'dull' amplifier is a nonsense, especially given that the 'dull' amplifier will be nothing of the sort as it'll almost certainly measure flat, and the dullness is just reputation, reinforced by repetition.I think that this is an over simplistic perspective. Surely you would agree that not all components, particularly speakers sound and measure (FR particularly) the same. Sometimes, particularly if you don't EQ, matching components makes sense... Or no?
Think your first sentence defines synergy rather well.I think amplifiers have to be appropriately specified for the speakers, but that's not the same as synergy in this context. The way synergy is used by hifi enthusiasts tends to be a way to compensate for coloured sound in one part of the chain using hardwired compensation rather than either just not buying the offending gear or by using tone controls/EQ.
Oh, it truly doesn’t.Another way to put it:
SUBJECTIVIST: believes that informal subjective listening impressions are the most reliable guide to evaluating audio equipment. One can “know” how audio equipment performs simply by this method, and subjective impressions rendered this way are more reliable methods of insight than objective measurements, or scientifically designed listening tests.
OBJECTIVIST: believes informal subjective listening impressions in of themselves are neither reliable enough nor sensitive enough to understand how audio gear performs. Therefore the objectivist holds that we can only “KNOW” how equipment performs by appeal to objective measurements, and by correlating measurements to listening tests, especially listening tests using scientific controls for bias.
So: IF this doesn't essentially capture the essence of the two approaches audiophiles so often argue about...
Nothing. It’s an inherently oversimplified labelling system. Little more than an attempt at intellectualised name-calling. That is exactly how it has been used in the past, and this thread is no different.what does?
Exactly, and this can be readily determined by the measurements. Loudspeaker sensitivity will determine power requirements, loudspeaker impedance characteristics determine amplifier load tolerance requirements. All easily found from measurement.I think amplifiers have to be appropriately specified for the speakers, but that's not the same as synergy in this context. The way synergy is used by hifi enthusiasts tends to be a way to compensate for coloured sound in one part of the chain using hardwired compensation rather than either just not buying the offending gear or by using tone controls/EQ.
Is that a subjective judgement?I'm just a grumpy old bastard.
And the term 'Audiophillia' - are you all tone deaf? - sounds like Kiddy Fiddler. I prefer 'Audio Enthusiast' but I think the boats already left on that one.I'm just a grumpy old bastard.
I am willing to submit to any double blind test and am confident to get 10 out of 10 right!Is that a subjective judgement?
Sounds nice in principle, not so easy to do in practice.No. All loudspeakers have frequency response errors, which can be corrected by equalisers. That's what they're for, and should be part of every loudspeaker system that doesn't use DSP equalised active loudspeakers. Trying to correct a , say, bright speaker with a 'dull' amplifier is a nonsense, especially given that the 'dull' amplifier will be nothing of the sort as it'll almost certainly measure flat, and the dullness is just reputation, reinforced by repetition.
Buy accurate components, equalise any remaining errors at source. There's no excuse whatsoever for components to have anything other than minor frequency response errors, easily equalised.
S
Serge have you ever made a mistake buying kit after reading the measurement? Admittedly my quest for Audio Nirvana has been littered with mistakes. Sometimes feel like a HiFi junkie, same high after the fix and the cold turkey come down when I admit it sounds like s***. This time Iv’e got it right at least until January?Exactly, and this can be readily determined by the measurements. Loudspeaker sensitivity will determine power requirements, loudspeaker impedance characteristics determine amplifier load tolerance requirements. All easily found from measurement.
S.
for most of us... it's a freakin' hobby.
