Audionaut
Or > From Spinorama to Living Room: How Much Survives?
I’d like to raise a question about system optimization that usually is seen here on ASR as a side issue at other Themes.
We put a lot of emphasis on designing loudspeakers to measure as close to “perfect” as possible: flat on-axis response, smooth directivity, low distortion, well-behaved off-axis curves. That makes sense, and I fully agree that a speaker should be fundamentally well-engineered.
However, in actual listening environments, the final result is heavily shaped by the room and by post-processing: room correction (Dirac, ARC, RoomFit), manual EQ, placement constraints, and acoustic treatment. In many setups, especially in normal living rooms, these factors introduce changes that are far larger than the residual imperfections of a well-designed speaker.
So one question is:
How much of the effort spent on achieving “near-perfect” anechoic performance actually survives in the final in-room result?
Or more provocatively:
Are we optimizing the right variables, or are we overfitting the loudspeaker itself while the dominant errors come from elsewhere?
So maybe the more relevant question is not “How perfect is the speaker in anechoic conditions?”, but:
“How robust is the speaker’s performance under real-world conditions and correction systems?”
Or, to put it another way:
After DSP and room correction, what’s actually left of that perfectly calibrated speaker?
I’m not arguing against good measurements – quite the opposite. But I’m wondering whether we should shift more focus toward system-level optimization instead of treating the loudspeaker as an isolated object.
Curious to hear your thoughts.
So one question is:
