Are there RCA/TRS cables with great interference protection?
Source link, please.
The miniDSP team doesn't have a track record of being experts on analog circuits, so they indeed might have screwed this up.
Understood. That's because that would be the wrong cable, with R and GND/shield not connected and then performance will indeed be compromised. That shown cable also wouldn't work optimal for their balanced outputs. While using only the T contact and leaving R open is correct, not using the shield makes this a very bad unbalanced cable prone to "ground loop noise". Rather, they should have specified a good coaxial cable with low shield impedance, terminated with a XLR female plug at the source end, connecting Pin3 (hot) and Pin1 (GND/Shield).
then performance can indeed be compromised.
Detailing on this: Even with R connected but GND/Shield not connected, the balanced receiver has to handle a lot more of common-mode voltage. And then the source impedance mismatch with the correspondingly reduced common-mode rejection takes its toll, as we can assume the receiver will likely be of the simple subtractor type.
No. See my posts in you recent thread. [/I]
I'm afraid I have not been able to grok your meaning, and apologize to all for my mistakes.
Could you maybe link to resources that explain all this down at my level, distinguishing between these myriad meanings if the word?
Ideally with practical wiring examples and advice about conversion device types...
Is this advice wrong?
12' for unbalanced?
Better to go digital instead?
Or at least do a balanced cable over the distance, proper "symmetrizer" close to the source SE RCA output.
For better high radio frequency interference rejection, the shield needs to be attached at both ends.
The connector needs to have its shield pin attached to the metal chassis with a short wire ( 1 cm / 3/4 inch).
I fear I cannot explain in in any simpler words than:
Balanced interfacing does not need a signal-balanced source, not at all. The magic -- the subtraction to extract the payload signal as sensed at the source -- happens in the receiver. (A+X) - (B+X) = A - B, with X being the so-called common-mode signal which is factored out, so it simply doesn't matter.
Yes exactly why I'm asking for help finding learning resources – written by others – to enable my actually being able to understand - just repeating it does not help.
Could you maybe link to resources that explain all this down at my level, distinguishing between these myriad meanings of the word?
You do understand the mathematical concept of subtraction? Otherwise, explanations in other resources won't help.
Anyway, less than 10 seconds of web search on "balanced signal transmission" pops up this, from Douglas Self (a very reputed electronic engineer and author of several books):
"2: THE BASICS OF BALANCING.
Balanced connections in an audio system are designed to reject both external noise, from power wiring etc, and also internal crosstalk from adacent signal cables. The basic principle of balanced interconnection is to get the signal you want by subtraction, using a three-wire connection. In many cases, one signal wire (the hot or in-phase) senses the actual output of the sending unit, while the other (the cold or phase-inverted) senses the unit's output-socket ground, and the difference between them gives the wanted signal. Any noise voltages that appear identically on both lines (ie common-mode signals) are in theory completely cancelled by the subtraction. In real life the subtraction falls short of perfection, as the gains via the hot and cold inputs will not be precisely the same, and the degree of discrimination actually achieved is called the Common-Mode Rejection Ratio, or CMRR."
(bold mine)
Thanks and yes, I'm au fait on all those components of balanced signaling.
That does not connect in my brain to those corrective posts you wrote that puzzled me originally?
But I've bookmarked them and will cycle back as I absorb more, I find this particular learning curve to be very much spiral shaped.
Well, we all started from nothing ;-)
I think the most important part to understand and memorize is that balanced connection allows the receiver to sense the signal right at the source, the mentioned remote sensing, and any disturbance downstream the cable is factored out. Whereas unbalanced signalling only sees what's happening at the output end of the cable, not what's happening at the input.
And the second thing is to remember that "balanced/unbalanced connection" are actually sort of misnomers which always leads to confusion.
Colloquially I guess could be seen as incorporating both the physical – cable type + terminations
and the signal structure, differential vs SE.
To me, "truly balanced" implies both are meeting all the conditions for both domains.
SE unbalanced seems straightforward.
It's the in-betweens, the various implementation differences, especially conversion methods where my head starts to hurt.
When you have a balanced input, then use it, by all means! Extend the "balancedness" with an XLR cable and put an RCA to XLR-Male adapter right to the turntable output (or use a custom cable termination to RCA at the source end).
What you need is this (note the right to left signal direction in this pic):
Edit: I see you have TRS inputs, but the scheme remains the same: The cable must be 3-conductor.
translating to a TRS connector...... the black wire will go the S(leeve) connection and should be the shield of the cable, the blue wire will go to the R(ing)and be one of twisted center conductors and the red will go to the T(ip) and be the other center conductor. And although electrically the Black and Blue wires are tied together DO NOT short them together at the TRS connector. This cable will only be for the input to the Balanced Flex from the turntable unbalanced output.
@PashkaTLT I am curious, what are the power cords for the 2 pieces of equipment? Is the turntable 2 prong and the Flex 3? Or both 2 or both 3?
Eaxctly.
