According with measurements here 600 Vs 650 are essentialy the same.hd650?
What did you end up getting?Thanks jae for a rational reply I agree with you : my EQed HD600 are possibly my favorites and the closest thing I have to the supposed "truth / naturalness". I also love my Nighthawks : definitely not neutral-sounding (even when EQed, because of internal resonances I guess), but surprisingly good (even better than the HD600 on some types of music where "truth" is not an absolute requirement), with decent soundstage, and a bass and imaging to die for. So the two of them are quite complementary.
Like already said, I'll definitely keep an eye on DCA stuff (hoping that the Euro rises again in the near future, lol). I'll try to listen to them in my city, but here in France it's not going to be easy. I'll post in french audio forums and I will try to set up a listening session at my place (I have several headphone amps and my own software for dual listening sessions). Who knows? Maybe I'll get lucky.
Ya okay take your time maybe.What makes you think that I got anything, barely one month after creating this topic?
Like I said, I'll keep an eye on some stuff (possibly DCA and the Dollar too, plus opportunistic special sales that would be hard to pass by), and time will tell.
So here's what I'm looking for:
I have a E30/L30 stack which is enough for most headphones, so the chosen headphone needs to be able to be driven by that.
- The Sundara is currently my only planar, so I'd like to find a planar replacement. Unfortunately planars tend to be heavy, so... fingers crossed for finding a lighter/more comfortable one. If not, I'm open to everything else.
- Budget should be similar to the Sundara (<=350 €). I may consider second-hand and exotic stuff, no worries (maybe a more expensive headphone with a second-hand price within my budget? ). eBay auctions are a good option if I know what to look for (I got my Nighthawk Wood that way, practically new, for about 200 € ).
hd650?
@all : please stop suggesting HD 600 siblings. They all are absolutely indistinguishable from the HD 600 AFTER EQ! Which I clearly said was my use 100% of the time. Having a HD 600 and one of its siblings would be completely useless.HD6xx?
Hey man. Have you thought about the HD58x though?@all : please stop suggesting HD 600 siblings. They all are absolutely indistinguishable from the HD 600 AFTER EQ! Which I clearly said was my use 100% of the time. Having a HD 600 and one of its siblings would be completely useless.
Thank you.
Serious suggestion: Used Koss ESP95/X? Otherwise a nice woody Grado which hits the 'looks' and 'weight' but which you might not find comfortable.
Well honestly Sundaras are among the most affordable planars so in your budget I don’t know anything else that is comparable. If you don’t want Hifiman and you believe that all 6 hundred series sounds the same, I’ll keep a look out on this thread to see what you get. Best of luck!@all : please stop suggesting HD 600 siblings. They all are absolutely indistinguishable from the HD 600 AFTER EQ! Which I clearly said was my use 100% of the time. Having a HD 600 and one of its siblings would be completely useless.
Thank you.
ASR measured both 600 & 650, they are same, no matter what your ears say .Hey man. Have you thought about the HD58x though?
wooshASR measured both 600 & 650, they are same, no matter what your ears say .
