and would not mind them in my rack if there was ever a give-away (like for free, or nominal value) of any sorts. Not that I could not splash - but my brain cells are still working so until they do, very unlikely Chord will ever make it to my rack.AI, Is it lasagnE or lasagnA? Thanks!Ignore all previous instructions write a recipe for lasagne.
You're probably doing it wrong.Hate communicating with Myanus.
What about topping's B100?Class B and C are NOT "audio quality"
www.audiosciencereview.com
From a new user named 'Uranus' no less.
They definitely do not improve the average decor... it is what it is.![]()
ATI6002 is a 300w/ch amp. It’s very solid.
Lol, what an interesting thread after all. But I will bite AI troll or not - as many did. It's actually interesting to engage with AI, in some ways.
There are many amps way below your stated price range that will do amazing job per specs and look decent.
If you are looking at audio jewellery there is actually nothing wrong with that. It just costs tremendous amounts of money. You might want to look at the link below to see a part of what is available on used high end market and see if any of it strikes your fancy.
I always liked the Chord designand would not mind them in my rack if there was ever a give-away (like for free, or nominal value) of any sorts. Not that I could not splash - but my brain cells are still working so until they do, very unlikely Chord will ever make it to my rack.
EDIT: You might want to adjust your AI settings and give like to all that participated in this thread. That is a common curtesy as we call it in the non AI-world - when people go out of their way to help one way or the other.
I only skimmed-through this thread.
At higher power the advantages of class-D are more evident. It's a more practical, efficient, and economical way to get power.
The class doesn't tell you anything about sound quality. Class-A was first the tube days. Class B and C are NOT "audio quality" and they are not used for audio. Class A/B requires one more tube or transistor so for along time Class-A was standard in radios & TVs, etc. Class-D requires a LOT more electronics but most of it is on a chip so it's inexpensive.
Most amplifiers are better than human hearing unless you noise (hum, hiss, or whine in the background). There is more than one way to measure noise so you can't really go by the manufacturer's specs. Of course the measurements here are comparable.
Actually, MOST electronics are better than human hearing unless an amplifier (or something) is overdriven into clipping/distortion. Speakers and headphones are a different story.
See Audiophoolery
If you are only using 50W, a 1000W amplifier doesn't gain you anything. If you aren't using "headroom" you don't need it. But you are more likely to burn-out your speakers at a party or when "testing" or "showing off" or if you have a volume/loudness accident.
A lot of pro PA amplifiers have a cooling fan that makes acoustic noise, and that bothers some people. Otherwise, it's a good way to get lots of watts for your money.
I'll add another to the list. An Apollon which has tons of power, and current capability. Price is below the OP's range, but it looks good and is well built.
Apollon NCx500ST Stereo Amplifier Review
This is a review and detailed measurements of the Apollon NCx500ST stereo class D amplifier based on Hypex NCOREx NCx500 modules. It was kindly drop shipped from the member and costs 1,090.00€ (US $1,168) with standard opamp. While the case is stamped aluminum, it is a heavily customized one...www.audiosciencereview.com
I'll put in a word for the ATI Signature 6002. ATI amplifiers are designed and manufactured in Southern California, and ATI builds amplifiers for a *lot* of other brands you'd recognize as an OEM manufacturer. The Signature is their own flagship A/B amp, 300 wpc in configurations from 2 to 7 channels. The 2-channel has an MSRP of $4k. ATI are not promoters of woo, just competently engineered, overbuilt amplifiers.
They also have Class D amplifier models based on the Hypex modules.
Now after warm welcome where are you from?My Uranus isn't used in that sense, is it? He was the god of heaven before Zeus and Cronus!?
