Jiraya369
- Joined
- Sep 2, 2025
- Messages
- 563
- Likes
- 532
you dont understand production. The main reason why calibrated or accurate stuff is required is so that everything translates.I think we all know that the premises around "the best sound is true to (insert latitude about linearity or ideal target curves here)" is flawed, because establishing the perfect, ideal performance to recording to mastering to consumer media is very elusive.
We know many recordings are produced with the idea in mind that consumers used flawed equipment. For Motown it was AM radio, now it's people like loudness and compression So it actually doesn't matter much which speakers or headphones are used in production, since the goal clearly is very seldom sonic perfection.
Let's say you have a bump at 1khz, due to that your ear adapts to it and so you hear everything with a bump and you more than likely will lower 1khz in your songs in the production process in order to make up for your speaker's bump. You CAN get used to the sound and mix well, but that doesn't make it the ideal method. You CAN climb a mountain whilst walking on a handstand, is that ideal? Now let's say you're a mountain climber who earns his money climbing mountains and competing with others, would you want to do the handstand or just walk on your legs to make sure you do your job as efficiently as possible?
In order to make sure the sound translates, the mixing engineers listen to the songs on multiple devices. For example, even an iPhone. Would you now say an iPhone is the holy grail for mixing?
The goal of a mixing engineer is to make something that sounds good or at least good to him and to make sure that the sound is conveyed faithfully to most consumer devices. It's why the Michael Jackson Thriller album sounds so good on so many systems, it was mixed flawlessly. If you have a poorly mixed track, it'll sound great on the system the mixing engineer used but not on other stuff.
Therefore, just because you can, doesn't mean you should.
